Hicas Light Stays On
my mate asked me the other day, why his HICAS light stays on when he is driving!
i have no idea!!
does anyone know wot this could indicate or wot this means!!
help would be greatly appreciated!!
im pretty certain his car has the HICAS lock...
cheers guyz...
Mine too, i'm not sure. I will try and sort it out this weekend.
I don't have the power steering hooked up at the minute, although may it just be the fuse or I can be far from it I onlt just drove my 32 for the first time the other day and have barley looked at it.
Wal
If he has a HICAS lock bar then that is the reason why the light is still on. You've removed the HICAS Rack from the car and it's telling you that there is a problem. Just pull the globe out of the back of the dash and you'll be fine
If he doesn't have the HICAS lock bar in and is still running the factory HICAS Rack in the car then he should take it to Nissan and get them to check it on the Consult to see what the problem is
There are so many reasons why the HICAS light can come on, and it can be a real pain to get rid of. Some really strange things have been known to set it off. Try simple solutions like topping up fluids, checking fuses etc. When my light came on, I just topped up the fluid reservoir (which wasnt THAT low) and it went off again.
thanks guys, yeah my hicas has been locked out electronically, so i have been told..... i definatley know its been locked out!! i may just pull the globe, seems like the easy way to fix it!! as hicas isnt being used!!
thankyou guys!!
cheers
my advice to u is, take it to an auto-electrician, preferably to nissan themself, but b4 you do that chek the fuse, if the fuse is blown then u cant do anything else urself coz thers about 20 components and about 50 wires u have to chek with a multi-metre yourself before you find the faulty component, i know from experience as this happend to my Honda Prelude Si 4WS, i spent about a day trying to find the faulty component, failed miserably, took it to honda and the guy found it in less than ten minutes, it was a wire that had been cut sumhow, so ye take it to nissan or sum other auto electrician
 Share
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
