  • Replies 42
Posted Images
http://metropolis.japantoday.com/lifeinjap...einjapaninc.htm
Much of the jobs seem to come through people seeking transfers
within companies.
You probaly would need some sort of skillset they would need in Japan , if you don`t speak the language.
Edited by CircusMonkey
https://www.sau.com.au/forums/topic/91093-japan/page/3/#findComment-1672336
