From http://www.exvitermini.com/
That said, the car is now being re-stripped and having the entire electrical system re-wired.  We can now remove all items that are required to be road legal, such as intrusion bars, doors, glass, air bags, seat belts and the various computer assisted controls that are no longer required (such as ABS, ATTESA and HICAS).
Maybe I'm being naive, but the idea of a GTR drag car is to use all FOUR wheels to deliver power ?
How would removing attesa be good ? It's just a 2wd GTS then!!
Just look at VL's.If you have sticky enough boot's and good sup setup I guess you don't need ATTESA,it's more weight to move.Also those 1000hp GTR's in japan only in 9's and the VL's are up with them.My 2cents.
  • 3 years later...
What fuse on the GTR R32's?!
I would love to be able to put it into full RWD for a bit... just to see how it handles...  <_<  :lol:
they handle terrible, but spin the wheels ok!!
there really meant to be 4wd and obviously designed like that..
and with regards to the dyno run, they probably pull out the front drive shaft, only 4 bolts underneath the car, to dyno it it. (if its a 33) 32s, just pull the 4wd fuse link.
I would have thought ATESSA would have detected no traction under the rear wheels and engaged the fronts ?
But would there be a lack of traction under the rears? The wheels are still turning the rollers?
The would not be lack of traction at the rear, but the large speed differential between the rotating rear wheels and stationary front wheels would make the ATTESSA system think there is a lack of traction and redistribute the power accordingly. Does that make any sense?
oops, haven't seen the vid. Assumed it was a 32.
You're correct, it is a little harder.
Ken
too hard obviously, not difficult to get those transfer cases smoking the clutch packs now is it. just visit gtr specialist workshops B)
yeah u must be far from an expert, the cam shaft control the opening and closing of valves to allow air into and out of the engine, then have nothing to do with ATTESSA
the shaft your are tihnk of may be the front drive shaft which goes from the transfer case to the front diff, yes as is mentioned above can be unbolted.
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
