0.8 bar :)
or 1 bar if you remove the restrictor in the boost line
thanx Duncan
got the profecb but dont know if my car has ceramics or n1s so ive been on min boost(0.5bar) im gonna dial up 0.8 thanx mate.
will ceramics handle 1 bar without tinkle tinkle down the exhaust pipe
1 bar will probably be OK......
But you can't run a GTR at .5bar even if the boost controller thinks you can. The minimum boost is always set by the wastegate pressure, and any extra boost you want above that is bled off by your boost controller.
I get 0.5bar on an Omoni a pillar guage so i probly should check how accurate it is before i use it to set max boost in case its reading low.
thanx again
  • 3 weeks later...
thanx again
Checked the pressure with another pressure guage and compressed air, waste gates opening at 0.6 bar and yes the omoni a pillar guage is reading 0.1 lower( should have realised this cause it sits at -0.1 when the engine is stopped, hmmm)
thanks again for zee help
