Item: 06/1996 Nissan Skyline R33 GTS25-t
Rego: Yes till March
RWC: YES
Transmission: 5SPD Manual
Engine: RB25DET
Mileage: 89,000kms
Reason for Selling: Looking at business venture, and need a more suitable vehicle.
Mods:
  • 3" Blitz NUR Stainless Steel Cat back exhaust
  • 19" Work VS Rims
    • Fronts: 19 x 8.5 (Brand New Rubber)
    • Rears: 19 x 9.5 (Good tread)
    [*]Nismo Clear Side Indicators
    [*]Nismo Black Gear Knob
    [*]Factory Optioned Rear Strut Brace
    [*]Factory Optioned Lip on Front Bar
    [*]GTR Rear Wing
More pictures can be found at http://kudosmotorsports.com/personal/R33/new
SOLD!
Contact Details:
Please note I am selling this car on behalf of my girlfriend but can help with any enquiries, besides I no more about the car than she does anyway :(
https://www.sau.com.au/forums/topic/91119-061996-r33-gts25-t/
  • 3 weeks later...
  • 2 months later...
This vehicle now sits on a set of 19" Work Vs rims and sports a 3" Blitz NUR exhaust system. So not only does it look hot but also sounds the part.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
