the following front coversion is now available:
skyline R33 to R34 :
including conversion fender, front bumper, bonnet and front light
Au$2588 + shipping
180sx to s15
Au$2588 + shipping
s14 to s15
Au$2588 + shipping
Integra DC2 to JDM DC2
including conversion fender, front bumper and bonnet
Au$1588 + shipping
Civic ek TO s14
Au$1588 + shipping
ORDER THROUGH [email protected]
LIMITED STOCK
https://www.sau.com.au/forums/topic/91123-front-conversion/
Would you have the rear wide body conversion for the r33 as well? Same as the Bee-R in the picture?
r33 wide body conversion is always available at our websit already.
the full bodykit + wide front and rear fender from au$1350 + shipping at limited stock.
price depents on different style.
please refer to our website at www.motorkitz.com
https://www.sau.com.au/forums/topic/91123-front-conversion/#findComment-1645386
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
