Item: AP engineering Power FC
Item Condition: New Condition..
Reason for Selling: GOt told it does not suit a r32 GTS4 (on this forum) and selling soon due to purchase of a new focus.
Price and Payment Conditions: $950 Buyer pays for postage.
Extra Info: Still in box with certificate and jap manual.
Contact Details: message first..
Item: Power FC with hand controller to suit Subaru Impressa
Reason for Selling: Rode of my old car.. did not get a chance to install it)
Price and Payment Conditions: $850 Buyer pays for postage.
Extra Info:
Also have a spare hand controler 415-x001.. (brand new in box) open to offers.. Brought this hand controller of ebay and found that it does not suit the AP engineering rb20det power fc.
Edited by tufrx3
https://www.sau.com.au/forums/topic/91127-fs/
Sorry it does not come with the hand controller.. i will be selling the car soon as l just brought a new focus, so there is no need for me to buy the commander. The commander that suits is a 415-n001 from memory...
Plus my car is a gts4 and l was told that its not suitable. The power fc is new, comes with box and manuals(jap) and certificate.
If anyone want a power fc commander 415-x001 l have a brand new one in box. Open to offers on this as l cannot use it.
I am selling this power fc cheap.. open to offers..
https://www.sau.com.au/forums/topic/91127-fs/#findComment-1643104
Would you be interested in a partial trade??? HKS VPC w/ GCC and r32 GTS-T/Top Secret ECU tuned for 550cc injectors, 60-1 Garret, Z32 MAF and Upgraded Fuel Walbro 255l, No Boost Cut, No Speed Cut, No Rev Limit ... Plus Cash.
Extra Info:
https://www.sau.com.au/forums/topic/91127-fs/#findComment-1650336
no idea.. can anyone veryfy this further..
I have pluged it in my car, an it did run fine.. But did not take the car for a drive, as it says that it needs to be tuned before driving it.. so l did not want to take any risks..
https://www.sau.com.au/forums/topic/91127-fs/#findComment-1652767
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
    • That's sick, thanks for that, mine has much the same mods on a 400R. I just don't have the heat exchanger yet.   Might be worth a trip down the M1 to Syndey for a tune.
