RB25DET Intake Plenum change
I'm puzzling over the best way to configure my RB25DET with a FMIC. I have assumed the best solution for airflow/lag reasons would be to position the throttle body at the front of the intake plenum to keep the return pipe length short and need some advice before i waste my time and money.
1. If i don't put the throttle body at the front of the plenum i will have to run the return intercooler pipe back along the length of the FMIC, up along the side of the engine and over the top to the standard throttle body position - this will introduce lag/air pressure restrictions won't it?
2. Cut/Shut existing plenum to position throttle body at the front. I was quoted $650.
3. Upgrade to custom plenum but then worry about added costs for fuel rails and injectors. Provides a good opportunity to upgrade injectors. Plenum $650-1000??, injectors and rail $1000+??
4. Will an RB26DETT plenum bolt up to the rb25? This would solve all my problems but i'm guessing no because I've never seen it done?
Anyone with comments please post up or suggest other options or contacts/workshops i could speak to about this.
Thanks,
Wegs
https://www.sau.com.au/forums/topic/9113-rb25det-intake-plenum-change/
  • Replies 63
unless your power goal is over 500 hp jsut keep the stock intake with the return there are people onhere makig well over 300 rwkw with the standard intake.
you money would be better spent else where
my cooler has is built with a return pipe under neath which is much better
meggala
Thanks meggala - I assume if i got hold of a rb26 plenum it wouldn't be a straight fit.
Extra power wasn't the driving force behind this idea - i want a responsive 250rwkw when i'm finished. Because i'll need to upgrade injectors at a later stage i wanted to consider all my options. I agree i'd rather save money for other areas which will show results provided i don't suffer from long piping. How did you find your turbo response after your FMIC upgrade?
Do you know anyone local (Melb) to supply the intercooler with pipe modification like yours? I won't accept dodgy tanks or core.
I have a Greddy plenum, cost $1500, and a mate of mine had his throttle body moved to the front of the plenum. Both of these options work perfectly well, but unless your after big power, like we are, then money is better spent elsewhere. These different plenum designs certainly reduced the amount of pipework and bends, reduce intake air heating etc, but it will all depend on what your end goal is to determine whether it is money well spent.
See'ya:burnout:
yeah mine is a race radiators one the tanks are flowed they are a great cooler my car only has an r33 turbo and cooler )its a r32 It has run a 14 flat with more in there so the cooler works very well I'm happy full boost by 3200 rpm its a good set up my site has other pics of my cooler int~~~
If you need to get an aftermarket intercooler then make the pipes as short as you can. If that means a plenum change, then if you have the cash go do it. Provided the throttle body size is kept stockish it should provide good throttle response and a nice fat power band.
The RB26 plenum won't fit straight up. It requires extensive machining. On top of that the multiple throttle body design is a son of a bitch to get right again if the linkages are moved and have not been marked.
this might sound stupid but couldnt you just take the rb25det plenum to somewhere that does alloy welding and get them to cut and relocate the throt body to the front and weld a plate where the throt body used to be ... it wouldnt cost 1/4 of the price ....
or is there more to it than that .. ie plenum internals ...
Thing to remeber is that you could pick up a set of 550cc top feed high impedence injectors, to go with the new plenum for $400-$500. The fuel rail might cost up to (tops) $200.
Side feed injectors generally are alot more expensive, expect to pay another $500+ for a set.
Sub Zero manufacture a plenum used on their 9sec GTST, it flows well and costs about $1400 and comes with a fuel rail and (I think) a throttle body. Add the cost of buying some injectors, then subtract the cost of selling your old injectors and plenum (if anyone wants to buy the plenum), and the cost of upgrading comes down to a few hundred dollars difference - in theory.
Some food for though
Steve
Doctor,
I know some people that used that design and they haven't had any issues as of yet. It was thought that with the internal baffles that the turbulance might cause some issues, but so far no problems. Sub-zero have used this design to good effect, so if your after a cheaper way out of redisigning your plenum then I think it is a good approach.
See'ya:burnout:
Ok, some very good feedback thanks people...it looks like the cheapest solution is to cut/shut the existing plenum.
Now to throw a spanner in the works....
I intend on changing my dump pipe and injectors down the track. The following thought comes to mind.
What if i use the full top end from an RB26dett?
1. Does it fit?
2. Assuming i can source a top end or blown bottom end complete engine, how much would i have to allow $$$ before labour?
3. Upgrades plenum, injectors, addition of twin turbo.
4. Need to modify dump pipe (easy)
5. Need new head gasket(how much $$?)
6. Could i bolt the head straight on or would it need to be reconditioned?
7. Any show stoppers that i've left out?
You can add the RB26 head to the RB25 bottom end, with only some minor changes necessary, but in my opinion I wouldn't bother unless you do a whole RB26 transplant. If your after big power then choose and RB26 engine or do an RB30 with RB25 head. The amount of money to do this could make the RB25 go very hard, so I'd suggest saving your money for that.
See'ya:burnout:
There are alot of local manufacturers starting to make inlet plenums at the moment, I know of 5 different people here in Perth, one is even making it out of carbon fibre. I'm not sure if any research into airflow goes into these designs, but even the cut&shut standard plenum gave a substantial increase in power to my mates car.
See'ya:burnout:
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
    • There are guys on Facebook under, Infiniti Owners Australia   https://www.facebook.com/share/g/1Z3RbPqx4k/?mibextid=wwXIfr What Whp are you after and I can help, and join this Q group in the states. https://www.facebook.com/share/g/19A59cN3JR/?mibextid=wwXIfr
