mmmmmmmm tacos......
you need to pull half your dash out and find a little green wire behind the dash that plugs into the stock tacho......
or jump it off the computer.....
hard to explain.. easy to do
is that anything like a mexican beer with a spicy bread roll???? :(
oh nice spelling BTW!
Bwhahahah, Good one.
If your going to pull the -ve pulse from the ECU be very very careful. You get the wrong wire you will end up with bigger problems then deciding where the hell you are going to mount a tacho that is for wank value anyways.
Cheers
Sumo
Not all people think that there for, how do you say it mate "WANK VALUE". different people like different things and if were all enthusiests about our carws and our skylines then we shouldnt have a go at someone just because they are doing something different.
Henzie i installed one the other day with the help of some mates.
First you need an "L.E.D" light detecter to find the wire that links into the computer, at idle it should flash at a slow regular pase and then under accelaration it will flash faster. strip the wire and join the green wire of the tacho then solder it together. Then all you have to do is find a continous power supply somwhere behind the dash and a power supply that workes when your lights are turned on and hook up the wires that the instructions tell you. And dont forget to earth it aswell. On a saturday i ran all the wires through and fitted the tacho to the dash and then on the sunday i had my mates help me find the right wire and solder everything together. All in all it would probably take about 40 to one houre to install everything.
