Heya,
I don't actually have a Skyline so that's why my rim widths are a bit smaller... but currently I'm after a new set of tyres (probably K104s) and was just wondering, what differences does profile and width make in terms of handling and response?
From what I gather, the lower the profile, the smaller the sidewall... so less flex, likewise for tyre width, as small as possible?
The rims originally came with 215/45/17 on front and 235/45/17 on the rear... I really don't care about road noise/comfort etc, just pure handling orientated...!
Any help/input is greatly appreciated... thanks!
PS: I've done a search but you guys seem to run wider rims then I do so the recommendations weren't much help :)
https://www.sau.com.au/forums/topic/91155-another-rimtyre-question/
Heya,
yes the lower the profile the less flex which helps when cornering. as for tyre width it depends on how much power your car is running, generally, the wider the tyres are the better grip you gonna get both in acceleration and braking. however if you are still running factory power then sometimes wider tyres and/or rims will actually degrade your performance.
Edited by GT Skyliner
Lower profile wheels will reduce sidewall flex, which helps to improve turn-in and feel. It won't necessarily improve traction, as the lack of deformity means you also don't get an increase in contact patch size as you load the tyre up. Because of that, it may actually decrease grip, although you'll really only notice it at the limit.
The lack of compliance will also affect your car's handling negatively on less-than-perfect surfaces, as well as increasing the risk of damaging a rim.
As Duncan pointed out to me when I had brain fade on another forum, wider rubber doesn't necessarily mean more grip. For the same car (same weight etc) and the tyres at the same pressure, the contact patch is the same size regardless of how wide your tyres are.
What does change is your track, which can improve handling. I believe that wider rubber is also more susceptible to tramlining.
The optimal width depends on a variety of factors. Wider rubber is great in high grip conditions, but you want narrower tyres in low grip. Having wide rubber tends to increase the possibility of aquaplaning.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
