Heya,
I don't actually have a Skyline so that's why my rim widths are a bit smaller... but currently I'm after a new set of tyres (probably K104s) and was just wondering, what differences does profile and width make in terms of handling and response?
From what I gather, the lower the profile, the smaller the sidewall... so less flex, likewise for tyre width, as small as possible?
The rims originally came with 215/45/17 on front and 235/45/17 on the rear... I really don't care about road noise/comfort etc, just pure handling orientated...!
Any help/input is greatly appreciated... thanks!
PS: I've done a search but you guys seem to run wider rims then I do so the recommendations weren't much help :)
https://www.sau.com.au/forums/topic/91155-another-rimtyre-question/
Heya,
yes the lower the profile the less flex which helps when cornering. as for tyre width it depends on how much power your car is running, generally, the wider the tyres are the better grip you gonna get both in acceleration and braking. however if you are still running factory power then sometimes wider tyres and/or rims will actually degrade your performance.
Edited by GT Skyliner
Lower profile wheels will reduce sidewall flex, which helps to improve turn-in and feel. It won't necessarily improve traction, as the lack of deformity means you also don't get an increase in contact patch size as you load the tyre up. Because of that, it may actually decrease grip, although you'll really only notice it at the limit.
The lack of compliance will also affect your car's handling negatively on less-than-perfect surfaces, as well as increasing the risk of damaging a rim.
As Duncan pointed out to me when I had brain fade on another forum, wider rubber doesn't necessarily mean more grip. For the same car (same weight etc) and the tyres at the same pressure, the contact patch is the same size regardless of how wide your tyres are.
What does change is your track, which can improve handling. I believe that wider rubber is also more susceptible to tramlining.
The optimal width depends on a variety of factors. Wider rubber is great in high grip conditions, but you want narrower tyres in low grip. Having wide rubber tends to increase the possibility of aquaplaning.
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
