Well since last time i have changed my power fc to a power fc d-jetro and raised boost 4psi. Power went from 511 to 608 rwhp. Heres the graph for anyone interested.
Engine is built rb26 2.6L still. Pistons , rods and HKS 272 cams.
Uses a single garrett to4z running 24psi.
Edited by R32-GTS
https://www.sau.com.au/forums/topic/91170-t04z-gtr-results/
  • Replies 95
Posted Images
good result simon, i thought the garrett t04z would only just make 600rwhp, so how much has it got left in the turbo?
picked up my hks t04z 0.81 housing turbo yesterday, lovely piece of work, cant wait to pump 25psi+ into it :P
Edited by StageZilla
https://www.sau.com.au/forums/topic/91170-t04z-gtr-results/#findComment-1643254
And gav drivability on the d jetro compared to the standard power fc seems better. Cold start etc is like factory and fuel consumption is much improved also. At 610 the 700cc injectors are now at 100% and if i wanna go any further i will probably get some 1000cc squirters. Still got one 044 pump in the tank.
https://www.sau.com.au/forums/topic/91170-t04z-gtr-results/#findComment-1643882
Managed to get a 10.91 @ 132mph at kwinana motorplex tonight.  I will go down again in a few weeks now that i have gotten used to it a bit. I think theres another few tenghts left in it.
so ppl get more of a idea, he was changing VERY slowly into 3rd
he also ran a 11.00 @ 100mph but jumped on brakes to try and save his dial in time... could have been around 10.6ish
good work poo poo, ill drive it next time cause ur too nice to the gearbox
Edited by Cerbera
https://www.sau.com.au/forums/topic/91170-t04z-gtr-results/#findComment-1643893
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
