Well since last time i have changed my power fc to a power fc d-jetro and raised boost 4psi. Power went from 511 to 608 rwhp. Heres the graph for anyone interested.
Engine is built rb26 2.6L still. Pistons , rods and HKS 272 cams.
Uses a single garrett to4z running 24psi.
Edited by R32-GTS
https://www.sau.com.au/forums/topic/91170-t04z-gtr-results/
  • Replies 95
Posted Images
good result simon, i thought the garrett t04z would only just make 600rwhp, so how much has it got left in the turbo?
picked up my hks t04z 0.81 housing turbo yesterday, lovely piece of work, cant wait to pump 25psi+ into it :P
Edited by StageZilla
https://www.sau.com.au/forums/topic/91170-t04z-gtr-results/#findComment-1643254
And gav drivability on the d jetro compared to the standard power fc seems better. Cold start etc is like factory and fuel consumption is much improved also. At 610 the 700cc injectors are now at 100% and if i wanna go any further i will probably get some 1000cc squirters. Still got one 044 pump in the tank.
https://www.sau.com.au/forums/topic/91170-t04z-gtr-results/#findComment-1643882
Managed to get a 10.91 @ 132mph at kwinana motorplex tonight.  I will go down again in a few weeks now that i have gotten used to it a bit. I think theres another few tenghts left in it.
so ppl get more of a idea, he was changing VERY slowly into 3rd
he also ran a 11.00 @ 100mph but jumped on brakes to try and save his dial in time... could have been around 10.6ish
good work poo poo, ill drive it next time cause ur too nice to the gearbox
Edited by Cerbera
https://www.sau.com.au/forums/topic/91170-t04z-gtr-results/#findComment-1643893
    • There's more than one way to skin that cat, and most of the sump Maatouks have done will be GTR sumps. They are HUGE in GTR drag racing here.
    • Yeah...I always start at the shift solenoids, because there's only a few reasons these will spook into limp mode, and bad shift solenoids is one ~ the other can be the shift control module (if you have steering wheel shift buttons)...it's easier to eliminate the solenoids first.
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 馃槄
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
