Hey brad weighed it yesterday was 1480kg without me in it. Has a nismo twin plate.
Turbostyler i changed to a d-jetro because the air flow metres wernt working to well with a single turbo as in light throttle cruise etc. . I dont think 2 rb20 afm's would have had any physical restriction. The maps dont interchange they are different.
Thanks for the reply much appreciated!
  • Replies 95
Posted Images
How on earth did you get away with the sub 11?
:) cheers :ph34r:
Simon ran a 10.97, then ANDRA warned him if he ran another sub-11 pass they would ban him. He then ran his 10.91 and was told not to return till he had a cage etc.
If anyone is interested here is a link to an Australian supplier of Garrett turbos.
TO4Z is $2,300.
http://www.tuneagent.com/public/content/Vi...gory.aspx?id=85
what are their contact phone number and where are they located?
Hi R32-GTS
Just wanted to say that is an awsome result and I'm sure there are alot of people who would even just sit in a car that had 600HP at the wheels.
Those Garret T04Z turbo's got to be one of the best turbo's out there, I've got one myself and get 560HP (417kw) at the wheels with 1.3bar (19 psi) boost.
I'd love to turn it up to 24 psi, maybe then I'd get a similar result.....
What are the modifications done to your engine, going into as much detail as possible. I have a fully built engine and it wouldn't be bad to compare.
One more thing, I run no air flow as well but use the Autronic SMC.
Thanks
Adam
PS. do you have any misfire problems or fouling plugs at that boost level?
There are a bit soft over there, one sub 11 and it's goodbye over here.
:angry: cheers :P
Hi R32-GTS
Thanks
Adam
How you going adam . If your only running 19psi on that turbo you will probably find you will be over 600 then at 24 + psi . It's hard to go into engine detail as most things have been done. Really just has Pauter rods , 87mm Arias Pistons , HKS metal head Gasket , HKS 272 272 10.25mm lift cams,hks valve springs , Jun oil pump , ported head , HKS valve guides , Tomei Cam studs , HKS Cam Gears , Trust sump extension and the usual smaller things. As with fouling plugs it hasnt as of yet but you do get a miss every now and then running that boost so i might gap the plugs down firther i think there gapped at .8mm atm. Still runs stock coils though.
Hey there R32-GTS
Thanks for the info!!
I run a similar setup but with HKS H-beam rods, 88mm HKS pistons, 1.6mm HKS headgasket, HKS step 2 280 280 10.25 lift cams, JUN oil pump, 8L sump, HKS valve spring,guides & the rest is HKS gear. A few things are changing right now though.
I run my plugs down to .6mm to avoid misfire & I use the Spitfire coils on them.
I don't have any real issues but I was wondering if running something like the Autronics 500R CDI unit or maybe the HKS CDI unit would help with a stronger spark & a better burn?
I've seen alot of GTR's with big HP upgrade their CDI & coil systems... any thoughts anyone?
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
