Thanks SK!!
Was hoping you could shed some light on this issue. As you could see we knew the CDI system must be superior but wasn't sure why and what benefits it would provide. The Autronics CDI with MSD coils seems popular. Motec must be a top of the line product as well
Well there goes my spitfire coils then, can't use it with the CDI setup. ;)
Would this system help in better economy, I understand that it produces a better burn so effiency would be better but the figures you have shown are in the higher rpm range.
If this saves on fuel cost's, then maybe in the long term it would help offset the cost. What about low rpm range, like highway driving?
I can see why it's not on the hot list for power increases, @$1600 (CDI & Coils) for only @40bhp but the other benefits look attractive as well.
What you think?
:) cheers :)
Adam
  • Replies 95
Posted Images
Not good then.
I really wanted to get to that 600HP mark but now I'm scared that my gearbox will not hold. Wouldn't mind spending the money on the OS Giken gearset if mine went but one day I'd like a GTR R34 and wanted to transplate as much gear as possible from my GTR R33. With the 6 speed Getrag box in the R34 you can't transplate it.
What are your thoughts on fixing the problem?
Second hand boxes are going cheap....
LESS POWER..... ;)
Alot of people are trying to get more POWER!!! B)
Trying to get less is.......can't even say the words.
Well I'm making around 560hp and my box is holding up, I might be making more then 560hp anyway cause I did an exhaust upgrade and really felt the difference but I haven't a dyno result to prove it.
Keep us informed on how it goes.
Best of luck with the gearbox anyway.
Edited by WetGTR
Yeh looks like another 32 gtr box going in . Might have to run less power on the street to keep the box together.
haah, lol, u r too viscous on the gearbox simon ive seen your driving b4 :) maybe doing a 1st to 3rd gear, drift on the previous corner helped haha jk
gets expensive when u buy a new gearbox each week ;)
Wow 1480 kgs is pretty light, was that with an empty tank and what sort of cage does it have?
;) cheers :)
I weighed my R32 GT-R at Calder 2 weeks ago (Thanks to Stephen) and it came up at 1554kgs with a full tank and no driver.
Regards
Andrew
Regards
Andrew
Thats 74kg heavier then mine although i only had 1/4 tank of fuel. I've taken all my hicass pumps and lines out which could be about 20kg and one turbo would be lighter then 2 i would say.
Time to try that cryogenic treatment Simon, might just do the trick.. and its not too expensive, so its worth a try ;)
Get Steve to rip a box open and take down the gearset and get it done.
Does this stuff work?
What would the cost be?
Wouldn't be bad to get i done before it chews a gearset up.
Going to try it
Congrats simon, that's an awesome resujlt!!! :)
I don't see 650-680rwhp being out the question with more boost (although i'd imagine 700 would be pushing it).
Those are some very impressive times you've run at the strip... i'm surprised they didn't kick you out for running faster than a 10.99? :)
As for the comment on running CDI with autronics to achieve over 500rwhp... well over 500rwhp is possible without it, its just a lot more fooling around (ie. getting very precise ign/fuel maps) to get the car running smoothly at the higher power levels, and whether or not you want to risk missfires at high rpm/power outputs...
Also, sydney kid, thanks for the info on your experiences with CDI... alot of it makes sense when you think about it! :)
Edit: Simon, how do you find the Nismo twin plate? Reasonably easy to drive? The reason I ask is for my own project... I'm looking into twin plates for it, and basically whatever comes up for the right price... most have been OS Giken's and Nismo's for the nissan boxes...
Having said that, I possibly have an OS Giken sprung center twiin plate which I can buy, however, my brother said it did NOT seem "easy to drive" like most people say the OS's are... he even thought his solid center HKS triple was easier to drive. It looked fine visually.
Are there just many versions of the OS giken twins, with some being really bastard?
Sorry for the offtopic, just thought i'd ask someone who has had experience with skylines! :)
Cheers,
Christian
Edited by Wobbz
Simon,
sorry to hear about the box. How much boost do you think you will be able to run from the garret turbo, the reason i ask is after talking to Garret australia about my garret ball bearing turbos they informed me the turbos were rated to 2 bar which doesnt leave a lot of room to move 3 to 4 psi more from your current 24psi yeah.
pete
  • 1 month later...
