Hey brad weighed it yesterday was 1480kg without me in it. Has a nismo twin plate.
Turbostyler i changed to a d-jetro because the air flow metres wernt working to well with a single turbo as in light throttle cruise etc. . I dont think 2 rb20 afm's would have had any physical restriction. The maps dont interchange they are different.
Thanks for the reply much appreciated!
  • Replies 95
Posted Images
How on earth did you get away with the sub 11?
:) cheers :ph34r:
Simon ran a 10.97, then ANDRA warned him if he ran another sub-11 pass they would ban him. He then ran his 10.91 and was told not to return till he had a cage etc.
If anyone is interested here is a link to an Australian supplier of Garrett turbos.
TO4Z is $2,300.
http://www.tuneagent.com/public/content/Vi...gory.aspx?id=85
what are their contact phone number and where are they located?
Hi R32-GTS
Just wanted to say that is an awsome result and I'm sure there are alot of people who would even just sit in a car that had 600HP at the wheels.
Those Garret T04Z turbo's got to be one of the best turbo's out there, I've got one myself and get 560HP (417kw) at the wheels with 1.3bar (19 psi) boost.
I'd love to turn it up to 24 psi, maybe then I'd get a similar result.....
What are the modifications done to your engine, going into as much detail as possible. I have a fully built engine and it wouldn't be bad to compare.
One more thing, I run no air flow as well but use the Autronic SMC.
Thanks
Adam
PS. do you have any misfire problems or fouling plugs at that boost level?
There are a bit soft over there, one sub 11 and it's goodbye over here.
:angry: cheers :P
Hi R32-GTS
Thanks
Adam
How you going adam . If your only running 19psi on that turbo you will probably find you will be over 600 then at 24 + psi . It's hard to go into engine detail as most things have been done. Really just has Pauter rods , 87mm Arias Pistons , HKS metal head Gasket , HKS 272 272 10.25mm lift cams,hks valve springs , Jun oil pump , ported head , HKS valve guides , Tomei Cam studs , HKS Cam Gears , Trust sump extension and the usual smaller things. As with fouling plugs it hasnt as of yet but you do get a miss every now and then running that boost so i might gap the plugs down firther i think there gapped at .8mm atm. Still runs stock coils though.
Hey there R32-GTS
Thanks for the info!!
I run a similar setup but with HKS H-beam rods, 88mm HKS pistons, 1.6mm HKS headgasket, HKS step 2 280 280 10.25 lift cams, JUN oil pump, 8L sump, HKS valve spring,guides & the rest is HKS gear. A few things are changing right now though.
I run my plugs down to .6mm to avoid misfire & I use the Spitfire coils on them.
I don't have any real issues but I was wondering if running something like the Autronics 500R CDI unit or maybe the HKS CDI unit would help with a stronger spark & a better burn?
I've seen alot of GTR's with big HP upgrade their CDI & coil systems... any thoughts anyone?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
    • I'd say one thing that may make you sell is the same reason the guy with the hard top roof sold his. He got old, and his back was giving him too much grief stopping him getting in and out... Old guy said he was 73! He looked and sounded younger than 73 to me! Or maybe I'm just aligning with old people more...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
