trying to figure out why my cur sux for cold starts. DAM IT
DUDE your car just sucks full stop ;)
Sell the lemon and stop spending money on it already and buy another freaking bike!!!
Clutch is slipping need a new one , installing turbosmart treg pro putting in mines rom ...
more boost
Car is being a bitch has some airflow meter issues, now is all sorted not its runs great but every now and then it will just run fine then stop for no reason? turn the key and its away with no issues?? WEIRD, in process of cleaning injectors any other ideas??
my new 48mm wastegate arrived today so that is on and the gearbox is back in. Just need oil for the box and get to test out 400rwkw on the street :)
You have no idea how much im hating you right now :wave:
Good luck with the shake down :)
Not a lemon, it was fine untill i touched it. LOL.
I can't sell it, cos it owes me money. If i sell it i would b lucky to get 16K for it. LOL.
:happy: 16k...
Tell em he's dreaming!!!
My clutch is fried. Getting Married in 2 months. Looks like my car will be in the garage for a while :(
Another one bites the dust :(
Thats what you get for letting your ms's drive your car James :O
:P unless she drives it harder than him :O
can you put it back to dead stock?, i know itd be painful but atleast then youll know if its something youve done or not. how much was the central20 ecu?. if all else fails you can borrow my car soon (i know mine is running sweet :( ) and switch a few things to see if it may fix it. also write a list of every single sensor youve replaced etc (inc mods) so you can test each one individually. Also have you cleaned your aac valve thingy?
Hay Toff.
back to stock, humm, not really, well time wise anyway. I have most of the parts, but the shear time invilved would be impossible to do so.
What i have done:
Fuel pump, and fuel filter. Going to put a new one in tonight and check that the antidrain valve on the tank is working.
New 02 sensor, have old, can try it, but i recon it won't make anyy differance
New ECU temp sensor, old was seamed ok, but the new one is definalty better, replace new with old, made no differance.
I have cleaned the AAC valve a few times now, and checked opperation, and i think that is working ok, i can adjust it with consults and it changes the rpm and so foth
Cold start valve, has not been checked as yet, i will see if i can test it properly tonight.
FMIC, there was no issues after this was fitted.
The central 20 ECU, ran the car fine for ages, it only started to be a dog in the last 2-3 weeks. Stock one sold, so i can't test that.
I have not checked injectors as shuch, i want to try all the things i can do for free, as i am sick of chucking money at the thing.
I am aslo going to check the radiator fluid to see if i don't have a head gasket problem anywhere, last night my water was low, which seamed strange, but the car doesn't blow any steam, or smell sweeet, or bubble through the radiator.
Kinda getting pissed off, i don't really want to spend more money on the thing, wife getting a bit enoyed and so forht.
I did a consult check and the the error code 13 and 21 came up.
13 is ecu temp sensor, started 13 times without this??? Going to investigate.
21 ignition signal, started 9 times with this, i pressume it's from when i did a compression check on the car, hence why no ignition source.
Commpression was an almost dead even 150psi accross all the cylinders, have not performed a leak down as yet.
This morning once again, the car was a odg to start. Howeve, if i just tap the accelerator on startup, the car goes fine, no splatter or anything.
So i am leaning towards a fuel delivery problem or something to do with cold start.
Anyway, toffy do you have a radiator pressurisation thing, to see if i have a blow headgasket. I hope i don't, don't want to spend more money on it. Should have taken the extra warranty. LOL.
Edited by WogsRus
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
