trying to figure out why my cur sux for cold starts. DAM IT
DUDE your car just sucks full stop ;)
Sell the lemon and stop spending money on it already and buy another freaking bike!!!
Clutch is slipping need a new one , installing turbosmart treg pro putting in mines rom ...
more boost
Car is being a bitch has some airflow meter issues, now is all sorted not its runs great but every now and then it will just run fine then stop for no reason? turn the key and its away with no issues?? WEIRD, in process of cleaning injectors any other ideas??
my new 48mm wastegate arrived today so that is on and the gearbox is back in. Just need oil for the box and get to test out 400rwkw on the street :)
You have no idea how much im hating you right now :wave:
Good luck with the shake down :)
Not a lemon, it was fine untill i touched it. LOL.
I can't sell it, cos it owes me money. If i sell it i would b lucky to get 16K for it. LOL.
:happy: 16k...
Tell em he's dreaming!!!
My clutch is fried. Getting Married in 2 months. Looks like my car will be in the garage for a while :(
Another one bites the dust :(
Thats what you get for letting your ms's drive your car James :O
:P unless she drives it harder than him :O
can you put it back to dead stock?, i know itd be painful but atleast then youll know if its something youve done or not. how much was the central20 ecu?. if all else fails you can borrow my car soon (i know mine is running sweet :( ) and switch a few things to see if it may fix it. also write a list of every single sensor youve replaced etc (inc mods) so you can test each one individually. Also have you cleaned your aac valve thingy?
Hay Toff.
back to stock, humm, not really, well time wise anyway. I have most of the parts, but the shear time invilved would be impossible to do so.
What i have done:
Fuel pump, and fuel filter. Going to put a new one in tonight and check that the antidrain valve on the tank is working.
New 02 sensor, have old, can try it, but i recon it won't make anyy differance
New ECU temp sensor, old was seamed ok, but the new one is definalty better, replace new with old, made no differance.
I have cleaned the AAC valve a few times now, and checked opperation, and i think that is working ok, i can adjust it with consults and it changes the rpm and so foth
Cold start valve, has not been checked as yet, i will see if i can test it properly tonight.
FMIC, there was no issues after this was fitted.
The central 20 ECU, ran the car fine for ages, it only started to be a dog in the last 2-3 weeks. Stock one sold, so i can't test that.
I have not checked injectors as shuch, i want to try all the things i can do for free, as i am sick of chucking money at the thing.
I am aslo going to check the radiator fluid to see if i don't have a head gasket problem anywhere, last night my water was low, which seamed strange, but the car doesn't blow any steam, or smell sweeet, or bubble through the radiator.
Kinda getting pissed off, i don't really want to spend more money on the thing, wife getting a bit enoyed and so forht.
I did a consult check and the the error code 13 and 21 came up.
13 is ecu temp sensor, started 13 times without this??? Going to investigate.
21 ignition signal, started 9 times with this, i pressume it's from when i did a compression check on the car, hence why no ignition source.
Commpression was an almost dead even 150psi accross all the cylinders, have not performed a leak down as yet.
This morning once again, the car was a odg to start. Howeve, if i just tap the accelerator on startup, the car goes fine, no splatter or anything.
So i am leaning towards a fuel delivery problem or something to do with cold start.
Anyway, toffy do you have a radiator pressurisation thing, to see if i have a blow headgasket. I hope i don't, don't want to spend more money on it. Should have taken the extra warranty. LOL.
Edited by WogsRus
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
