My car got reversed into the front of last night. :):O:domokun: The front bar has a crack in it from the headlight down to the bottom of the numberplate mount roughly. Fair bit of paint scratched off the bar as well. Going to need a new front bar so the bodyworks place told me. Bonnet is also a little bit bent in. :banana:
some more power on the way, need to move house first dam it.
Well come on then, spill it...
My car got reversed into the front of last night. :banana::):domokun: The front bar has a crack in it from the headlight down to the bottom of the numberplate mount roughly. Fair bit of paint scratched off the bar as well. Going to need a new front bar so the bodyworks place told me. Bonnet is also a little bit bent in. :domokun:
DAMN dude thats not good news, are you able to plastic weld the bar???
I'll give ya a buzz about the AFM 2morrow after i ring the PO :O
Well lets just say i need a some new injectors and a new AFM but the rest is on the way, also a cam gear ordered. Not sure about power figures, still aiming for 250 rwKw but anything above 230 and i'de be happy. Hopefully Nick will sought out my current issues with the car LOL.
She's gona be different allright. LOL.
Wog being different..... :rolleyes:
The bar is a fibreglass bar fortunately so that is being repaired as i type. Should get it back next week and then off to the bodyworks for the front bar to be resprayed and then getting the bonnet and the driverside door resprayed as they are both a little bit patchy. Wasn't planning on doing them until later in the year but might as well get them done while its there.
Best make a copy of that East Bear front bar... 'just incase' on the track next year!
New rims on the way and just ordered an east bear front bar. Won't get the bar till the end of August though.
Well its been a slow process getting my snotter on the road again.
This weather is the main killer at the moment as i dont have a shed/garage the car is just in the drive which means on days like today i cant get anything done :)
Basically to get the car running:
starter motor bolted back on
couple of heater hoses attatched
FMIC piping bolted up with a few adjustments
run all new vacuum lines (and figure out the mess from the old EBC) along with the electrics for the EBC
redo fuel lines (have to disconnect the additional 2 lines) and also the 2 extra injectors.
put ignition barrel back in and fix wiring where it was damaged
have new 1/4 glass put in
put rotors back on (getting machined today) along with freshly painted calipers and bleed brakes
sort out rest of the engine bay wiring which looks like a scattered birds nest...
and then there are a few other little things that needs to be done before i can pit pass it :O
Atleast my new parts lists looks good if Australia Post stop loosing my freaking gear :)
Sweet, snapped my rear cradle last night.. Dunno what the go is there.. ANYWAY if anyone has a hell cheap reliable daily for me with rego (under $1000) ring 0409869892 TODAY as I decided that my car is actually slow as shit and may aswell work it while it is off the road now.. Cheers, Jayson
well my new coils arrive today, turned out 4 were fried, replaced under warranty. Was told it was due to improper earthing, strange. SO i ordered an R33GTST specific earhting kit for the whole car, battery boot engine ect, from teh UK, briliant kit, $130 later.
Turbo arrivs this week, searching for new injectors and new AFM.
Little strange about the earthing problems cobber...
What turbo did you end up going with???
Why not just buy Z32 from CRD and injectors from Aaron as they are the cheapest???
The turbo well it's that Rx7 Hybrid.
Once i get it i'll measure the A/R and see what's what.
Yeah the earthign is very bizzar, maybe that is what my problems are. Looks like a job for an auto sparky.
Well with the injectors i was hoping to get some 440cc ones from my contact in the US about $390 Au for a set of 6 delivered and yeah slide for the Z32.
BUT have to move house first.
I didn't know that made side feed in 440's???
This weather is killing me, i have all the time in the world and cant spend any of it on the car and its so freaking close to being alive again :P
yeah in the us the 240SX came with them.
Ah ic...
UPDATES: rotors machined but will be the last time before i have to replace them :)
Replaced broken brake line fittings so hopefully that stops the leaks and increases pedal feel again...
Pulled my BRIDE out and fixed the runners so it can slide again and after sitting in it again im thinking of selling it as its too narrow in the base ;)
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
    • Please noooooooo 😭 As for wrap, no thank you mate, I've seen and used "carbon fibre" wrap before, and for these hard tops, they look soooo good when colour matched Like this >>>
    • That depends, someone might offer me a good price to resell it Mark... Ha ha ha!   I can get it wrapped in a really nice looking carbon fiber vynil if you want?
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
