GMB - I have Steve Caplice engineering the car, and I have an sr20de to drop in, I would like to go turbo, but on a bit of a budget, I might strap on a turbo later on for power to weight ratios around Ferarri territory :P
Anyway, I just picked up a steering rack from Todd, which lines up very nicely, and hopefully picking up a pair of hubs from Damo tomorrow - if he hasnt fogotten me and tells me where from - hint, hint :P
GMB - I have Steve Caplice engineering the car, and I have an sr20de to drop in, I would like to go turbo, but on a bit of a budget, I might strap on a turbo later on for power to weight ratios around Ferarri territory >_<
Anyway, I just picked up a steering rack from Todd, which lines up very nicely, and hopefully picking up a pair of hubs from Damo tomorrow - if he hasnt fogotten me and tells me where from - hint, hint :w00t:
Ah your in good hands then :D
Sounds like its coming along pretty well for you, whats the plan for it: track, hill climbs, weekender???
Progress on my car isn't bad but i need to borrow a stock afm asap before i can do much more :banana:
well a big update for me.
surge tank and fuel system is in and running. oil cooler fitted. 25mm spacers and guard flaring done. injectors in and working. power FC in, modified and running. basicly only heaps of very minor jobs to do and its all finished.
i took it for a quick spin around the yard :D and i think it will be ok. haha.
How good are the guards though!!!!!! I have NEVER seen a set of guards rolled and flared so well, it's just a shame the rest of the work on the car isn't quite at that high standard.
Definatly in good hands ;)
But I can sympathise with you tho - sometimes parts just seem to fall out of the sky, other times... well
I am thinking the car will mostly be for weekend blats around back roads, but definatly a few hillclimbs, sprints and track days - Hopefully giving you skyline boys a run for your money :)
Definatly in good hands :D
I am thinking the car will mostly be for weekend blats around back roads, but definatly a few hillclimbs, sprints and track days - Hopefully giving you skyline boys a run for your money :(
Tell me about it, all i need to do is borrow one for about an hour and then i can progress.
Looks like i will be doing other things over the weekend now instead of working on the car ;)
hasn't your car been off the rd for almost 2yrs now glover?? what's going on with it?
Pretty close to its 2nd Birthday yeah :D
The car is ready but experiencing a few little electrical problems stopping me at the moment. Just waiting to get some coin together to get someone to look at it then hopefully turn the key so its running then tidy everything up, install parts and tune.
Busy this weekend with a wedding but *touch wood* i can get someone to look at it next week and have it running :)
My FMIC & Coilovers arrived from GReddy Japan finally and are getting fitted on my R34 GTR tomorrow! I'm soooooo excited!
Still searching for a nice carbon fibre bonnet, some ganadors will be going on soon too I think, a few other little things, clear indicators etc then new Deeeeeeeep Dish rims (My R34 GTR Rims will be for sale!) and then on to some internal work and making my final decision on what turbo/turbos to run....
So exciting :D
Pretty close to its 2nd Birthday yeah :P
Busy this weekend with a wedding but *touch wood* i can get someone to look at it next week and have it running :P
what kind of problems dude? i can have a look for you, know rb wiring pretty well now :P
what kind of problems dude? i can have a look for you, know rb wiring pretty well now :ninja:
Going to remove the starter motor and bench test it to make 100% sure its ok then just go over all the wiring again.
I will be calling on Pimping Kustoms to do my gauges though :(
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
