I spent today getting hella dirty swapping engines in the bluebird, fark old cars suck!
:) depends how old and what motor, changed the motor in the FC in a little over an hour from go to woe and barely got dirty :)
:woot: depends how old and what motor, changed the motor in the FC in a little over an hour from go to woe and barely got dirty :D
Like everything is an inch thick in grime, should have really taken to it with a pressure washer first, but meh too late now.
can tell a butcher has been working on it though, that many stripped bolt heads over tightened bolts.. my temper is limited haha!
hopefully its going again tomorrow if burson's is open and i can get the last few things i need.
Will be fun to drive the old girl again and even more fun when its wearing the old LCA's and coilovers from my silvia.
Would love to throw an S13 rack in it also to get rid of bump steer, but im not quite that enthusiastic just yet.
Had my R31 tuned at Dr Drift's yesterday, 240 @ 13.5psi, 255 @ 15.5psi & 265 @ 19.5psi.
thats not bad, not bad at all! what kind of setup are u running in the R31? last tune i had (will not mention by who :domokun: ) was dissapointing and only reached 250rwkw @15psi . I know it is capable of more with the existing mods but was given more excuses yet again, so thats why i was waiting for Dr. Drift to come down, i didnt think he was coming till the end of the month? suppose i have missed him again???.......!!!!!!!!!!!!
I'm in Melb at the moment. Not much in the way of mods, TD06 and that's about it. Rb25 doesn't even have VCT.
He will be in launceston in a couple of weeks.
oh and to update for my car. i have dropped off my re-designed cooler piping to a profered workshop to be welded up wich should save on lost time with blown cooler piping again.
i am very happy with the new setup. hi compression turbo for the win. while it lasts anyway.
got the seats in, spacers on and ps pump changed today. car is now going again.
all that is left is pod filter, mount battery, modify cooler piping, longer studs up front and fit speedo sender. (oh and chase a rattle in the rear that is shitting me!)
then it is ready to put on the market properly! actually starting to be quite a nice car, might even change my mind and keep it for a little while.
here are a few pics of the car
Came home this arvo from easter lunch at the old ladies to find the gate open and someone had decided to help themselves to parts from my car :cool:
Happy farking easter to who ever it was and thank you very much, i have the rego number, make, model of the car and a description of 2 people who were there. You guys should know that old people with nothing better to do make the best neighbors in situations like these and you will have whats coming to you very shortly you low life pr!cks!!!
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
