looks good mate
got my boost controller ;) should be in this weekend :D
Nice to see you're settling into the skyline scene... car is looking the goods also.
GTR UPDATES:
Block has been all machined, all the component balancing has been done and almost ready to be assembled
got ACL bearings to go in and CP Pistons
also the head is being reconditioned as it was a bit worse for wear aswel.....just my luck
pretty much everything in the engine has been replaced or freshened up....
also i have to go on:
Garrett TO4Z 700HP turbo
Speed-flow oil/water lines
Turbosmart 50mm Wastegate
Extreme turbo manifolds Highmount manifold (top notch work)
Custom Dumpipe
Greddy "y" afm pipe
few other bits and pieces, its getting there slowly, Just doin the engine bay in gloss black at the moment aswel.
still alot of work ahead... :D
righto, havnt done this in a while, or at all for that matter
anyway, just finished putting my new hks gtrs turbo on the 32, along with sard 550cc injectors, adjustable cam gears, timing belt and water pump.
now its down to what ecu im gonna chuck at it, a rb26dett power fc is looking the goods at the moment, heard from damo that with some small changes she'll run alright! (will contact you damo when ive got he coin to buy one, so you can show me what i gotta do exactly! :D )
hopefully it will be half reliable and more club days and some drift days to come
now its down to what ecu im gonna chuck at it, a rb26dett power fc is looking the goods at the moment, heard from damo that with some small changes she'll run alright! (will contact you damo when ive got he coin to buy one, so you can show me what i gotta do exactly! ;) )
yep do some research on the injectors + power fc match up and it should be sweet. i may also be able to help with the tuning side of things to.
  • 4 weeks later...
my new car...
back in the skyline game, i am pretty sure the motor is close to rooted (rings only hopefully) but will just go through the motions to nut out exactly why it is using a butt load of oil and will sort it out.
all in all, pretty happy with it, R33s are so nice to drive!
i should have another skyline by next week, looking to secure a series 2 gts25t from either melbourne or japan if i luck out on the local market.
for now though the rx7 cage and interior are painted...
Thats a nice looking 33 Todd!
I cant say I've driven a 32 or any other Nissan, but I love the way my 33 feels on the road.
On an update note, in the process of putting on a FMIC, just need to grab a nipple for the cooler piping/boost actuator and a large whole saw :blush: will have tomorrow.
I fired up my 25/30 tonight. It sounds pretty tough. It took just over 7lts of oil and over 11lts of trans fluid for the auto
did you happen to change engine biulders half way through the 25/30 biuld project.
my new car...
got some 18's that would cool on this car 4sale
Fuel Pump ordered, and Split-Dump/Front pipe just arrived.
Intercooler is completely on, and I know that they arnt actually suppose to make any more power, but the car feels stronger. Definitly more pull from 4500-redline, and the induction sounds better too.
The bottom end was from pro engines as ronnie was to busy at the time i wanted to do the build as it was mean to be ready for powercruise. So he has done all the head work to suit and to fit up the auto.
I dont know how long this engine will be in the car for as im looking into a 3.4lt stroker kit for the rb30 :)
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
