  • 3 weeks later...
Well my 32 GTR is on the hoist, and about to under go a full overhaul
new motor is built, just a set of CP forged piston's and some Nismo rod's, Tomei sump baffle, Kelford cam's, OS giken cam gear's,
OS giken twin plate clutch and moly flywheel, still need to decide ona fuel rail and injector size
Have removed engine and box, also complete front suspention and x-member, and have stripped to engine bay of everything,
and it's in bare metal ready for a little bit of seam welding here and there, then it's paint time have picked a colour but i not letting
the cat out of the bag on that one....:rolleyes:
here are a few pic's,
post-70098-0-82268400-1299374953_thumb.jpgpost-70098-0-15321200-1299374972_thumb.jpgpost-70098-0-94182900-1299374981_thumb.jpgpost-70098-0-51070500-1299375042_thumb.jpgpost-70098-0-15163300-1299375128_thumb.jpgpost-70098-0-47154900-1299375142_thumb.jpgpost-70098-0-01741000-1299375156_thumb.jpg
Hey zoidbergmerc yeah its a 26 out of a 94 model Vspec1 but it had the longer crank in it and i just got a basic budget reco (as budget as you can anyway) but its basically got Ross forged pistons, nitto rods, ACL bearings, oil restrictors, external oil drain, hi octane sump extension, basic head reco with heavy duty valve springs for poncams later on etc. Really just a full refresh with no heavy machining or over the top parts. I figured if i went all out on it and something went wrong then i would'nt have the money to do it again so i just tried to get away with as much as possible while fixing the factory probs and making it more reliable. I mean nissan knew what they were doing and stock these engines are capable of decent power so with a few new bits it should do what i want for as long as i want well hopefully anyway lol. I would get some pics up but im really struggling to do that ive got them off my iphone and onto picasa3 but i cant seem to get them onto SAU so if anyones got any tips they'd be much appreciated.
Hey mate, where did u get ur engine work done? Wot power r u hoping to make? And wot fuel system r u running?
Hey I pulled the engine out myself but my mate works at Tas Engine Reco in Hobart so they did all the work. I'm putting Garrett -5s on it so I'm hoping for around 340-380kw obviously closer to 380 would be better lol but I guess it all depends on the tuner it should be good for 400 in theory but you know how things vary. As for fuel system I haven't got anything sorted out yet but I have removed all my hicas stuff apart from the hard lines from the front to back and I've heard something about converting them to fuel feed lines cause they're bigger than the factory ones or something like that but I'll work it out. Other than that just a decent intank feeding a surge tank with an external feeding the injectors havent looked at any brands yet. My mate got I think it's siemens injectors in a kit with a rail reg and lines pretty cheap through his work on his 25 and they seem to do the job well. So I'll probably go with those. But really at the moment just a saving game lol. It's true GTR owners are all poor aren't they lol.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
