Syncro and selector wear has more to do with the mushy thing attached to the gear stick than the actual gear stick/knob :thumbsup:
That mushy thing is by far the worst bit about my car.
thats what i want to know, i change gear as i normally would, i don't grab the top of it to change gears (i hold it at the bottom) & I don't smash through them either
I love it!!!
My R33 Gtst (RB25Det) has intermittent power problems.
When it gets into the high end revs the power backs off and it doesn't pull the way it should.
Need to get it dyno'd to see what the problem is.
Don't waste your time on a dyno... you can troubleshoot your problems yourself.
Ign issue, fuel delivery issue or flow restriction- etc.
J.
R33 RB25DET, has is got a Front Mount Intercooler???, most common drama if it has is the spark isn't strong enough..
best way to diagnose is pull you spark plug's, re gap them down to .9mm refit and run it, if it clear's the problem then spend up on some good coil pack's..
if you don't wanna spend the money on coil's, just leave the plug gap at 0.9...
as a side note BA XR6 turbo falcon, run's a plug with a .9 gap that fit's the RB25..
Finally got the engine slotted into the GTR on the weekend with the help of Jack. Still a bit left to do but it's a good motivator to have it sitting in there looks pretty sweet too.
post-58307-0-07352000-1321869490_thumb.jpg post-58307-0-36351900-1321869559_thumb.jpg post-58307-0-95812100-1321869622_thumb.jpg post-58307-0-08912900-1321869671_thumb.jpg post-58307-0-14724800-1321869456_thumb.jpg
I was trying to look at the engine but was unfortunately blinded by Jack's legs...
Damn nice engine mate, you must be happy with that ;)
Cheers guys and yeah I'm bloody stoked just cant wait to get it going now. Coming upto 2 years now since it was last on the road and I wanna drive it lol. Yeah Toffy spent almost $20,000 so far and it's still not running not really satisfying yet but it will be! Guess thats the only problem buying one that's stock you have to spend $$ to rebuild it but then you also have to spend that again on supporting mods. Oh well I knew what I was in for when I bought it and thats WHY I bought it.
haha to think i actually had a tan 6 months or so ago. wont take long and the frosty white will brown up again! I'm still Ridiculously good looking, working on my new look, blue steel hahaha lol
yeah the donk is worth a dime or two, glad the rope held up when it was going in!
hey guys im thinking about putting the stock body kit and dumping my 34 on its ass :D so it just looks like a low neat stock 34
the body kit makes it look low but as you can see from the guard gap to the wheel its not :(294092_10150343399640866_707545865_8683430_1430285945_n.jpgaany thought on this would be nice :D166613_193814530644446_100000477008080_713215_6854574_n.jpg i have F!@#ED the fiberglass frount off and put a stock one on ..
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
