hmm might have to look at that,
anyway bigger problem, wheel nuts were torqued on to hell, so used a breaker bar, then got the lower bolt off easy, went to do the first on the strut top and struggled went to use the breaker bar and it slipped, i think i may have stripped it a bit, so now dont know what to do :S
I had the same trouble with one of my strut tops, it already had 2 stripped nuts. i just used a Nut & Bolt Grip Extractor. You should be able to pick a set up from bursons, repco etc.
so i went and bought some new sockets to go on my 1/2 inch breaker and with almost zero effore the nuts came off, even the slightly damaged one... so now ive installed fronts, and ill have to wait till another day to do the rears... which will be more fun!
so that was the biggest mofo ever, went onto doing the rears last week and the nut and stud were spinning together so had to work out how to get the parcel shelf out... couldnt, left it till after work the other day and removed two supports on the left and right that the parcel shelf sits on cause the 6 x 9 were in the way... and had to use vice grips to hold the stud and remove the nut... but got it done... now to test drive...
btw the rear on the r33 is a b***h but i guess if i ever have to do it again i know how :s
Stuck my flares on yesterday so I didn't get raped on the way to baskerville.
Will be rolling the guards this week some time as they scrubbed all the way there and back and then I'll sick the flares on for good
that looks tough as now! Loving the bolt ons.
Don't worry about rolling, just cut it!
I would have but in case I decide to change wheels at a later date I just rolled/pumped them & that turned out awesome....
picture time
see turned out just awesome -_- not 100% finished
A little Mexican ( 15x10-26 195/50 ) still need to decide if im going to roll/pump these also
Needs more low, although as is it makes some lovely sparks from the chassis rails
Edited by Autumn33
Might take you up on that, I'll send you a text when I'm down that way next,thanks
Not sure if you can see in the pics, my rear guard has sucked itself in I'll get a better picture today
how did that even happen? Do you reckon the old heat it up with a hair dryer and cool it down with a tin on compressed air upside down trick with fix it?
Edited by zoidbergmerc
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
