hmm might have to look at that,
anyway bigger problem, wheel nuts were torqued on to hell, so used a breaker bar, then got the lower bolt off easy, went to do the first on the strut top and struggled went to use the breaker bar and it slipped, i think i may have stripped it a bit, so now dont know what to do :S
I had the same trouble with one of my strut tops, it already had 2 stripped nuts. i just used a Nut & Bolt Grip Extractor. You should be able to pick a set up from bursons, repco etc.
so i went and bought some new sockets to go on my 1/2 inch breaker and with almost zero effore the nuts came off, even the slightly damaged one... so now ive installed fronts, and ill have to wait till another day to do the rears... which will be more fun!
so that was the biggest mofo ever, went onto doing the rears last week and the nut and stud were spinning together so had to work out how to get the parcel shelf out... couldnt, left it till after work the other day and removed two supports on the left and right that the parcel shelf sits on cause the 6 x 9 were in the way... and had to use vice grips to hold the stud and remove the nut... but got it done... now to test drive...
btw the rear on the r33 is a b***h but i guess if i ever have to do it again i know how :s
Stuck my flares on yesterday so I didn't get raped on the way to baskerville.
Will be rolling the guards this week some time as they scrubbed all the way there and back and then I'll sick the flares on for good
that looks tough as now! Loving the bolt ons.
Don't worry about rolling, just cut it!
I would have but in case I decide to change wheels at a later date I just rolled/pumped them & that turned out awesome....
picture time
see turned out just awesome -_- not 100% finished
A little Mexican ( 15x10-26 195/50 ) still need to decide if im going to roll/pump these also
Needs more low, although as is it makes some lovely sparks from the chassis rails
Edited by Autumn33
Might take you up on that, I'll send you a text when I'm down that way next,thanks
Not sure if you can see in the pics, my rear guard has sucked itself in I'll get a better picture today
how did that even happen? Do you reckon the old heat it up with a hair dryer and cool it down with a tin on compressed air upside down trick with fix it?
Edited by zoidbergmerc
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
