cheers Frosty. 1990 Ti model with manual conversion, electrics all work, replaced original cut springs and shocks as it was sitting on the ground and the shocks were 100% rooted.
Sure it looked cool being lower.. but not practical as i couldnt even get in and out of my drive way properly.. eg below (got beached maybe once or twice and the cat got hammered, eventually blew a gasket)
Edited by Funz
Well i dont accaly think ive ever posted up my currant project on here so heres a bit of a run down
Of what ive been up to it was a crashed car runing with rb20det i paid $2000 for heres a run down of some of the parts in a very random order or whats on/in car and what i have to go on
Rb25det, kkr430, forward facing plenum, normal fmi and 3 inch exhaust (with proper 3 inch muffler)
Coilovers, rear camber arms, hicas lock bar, caster arms, r33 lcas
Extra lock spacers, longer wheel studs, 52mm radiator, bride seat on low mount rail, 044 and surge tank,
18x9.5 and 18x10 veil side andrew v wheels, toyo r1r on front, r33 front brakes,
Power fc
Dont mind the front bar ive got a gtr copy bar lined up to suit rest of kit
Edited by lawler
  • 3 weeks later...
30, more torque, cheaper. decent turbo setup will just defeat a 20... Plus a 30 is already in there?
this.
find a manual conversion kit.
will end up being around the same price as a 20 swap.
just de pigying my 32 fixing all the faults and legalising it :P
if anyone ever has a problem with oil filling there sparkplug galleys in rb##det because of some dead shit thinking gasket goo will do.. ( n i meen fill like submerge ur spark plugs compleatly)
my method was a shit tone of degreaser shove it right in there and sponge it up with a rag and string it out, keep going til its as cleen as u canon all 6 galleys, and then degreaser and compressed air til nic n cleane and leave it to dry i repeted all the prosess 3 times for all 6 galleys that was enoigth, when i was blowing it out i covered up the bay, exterior and window etc completely only exposing the head of the rb, so yeah dont leave ur head covers unsealed corectly for any drastic amount of time guy$ :P i really made sure it was clean i coukdnt risk and bit going into the bore and seizing it when i change the plugs abd it was just nasty and probly somewhat flamible
Power fc
nice work m8 are u interested in selling the front bar mind u ill probly end up cutting sonething like that down to meet 100mm + off grond probly be trying to get my car 13 cm of ground at front it hitts everything even if i angle it and go supper slow at. 12cm with a busted bar :/
Cheers guys , I've made my mind up , the 30 will stay , with turbo kit , when it blows I'll slap the 20 in :D , I have a flowed 25 turbo , gtr injectors and a z32 laying about I'm sooo tempted to whack on the 30 , I doubt the gearbox will take it for long though lol
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
