Nah just saw it on there. Was considering putting a bid on it but decided I probably have too many cars as it is. Looked like a pretty easy repair
Yep , i wasn't going to bid on it either , but i was on there watching something else :blush: , if the damage is worse than it looks in the pics i'll probably just wreck it
Buy the rota p45 from Rota aus on facebook, $1099 including delivery for 18's
cheers for the heads up, just checked them out wanted to go 18x9.5 +12 & 18x12 +20
but i dont want to hack my front guards or go wide rear, so thinking i may have to go 9.5 +32 & 10 + 35 :glare:
as im thinking +12 all round would still need guard work even though mine are allready rolled
interesting, mines quite abit lower then yours though.
i failed before the fronts would be +25 not +32
they have.
18x9.5 +12, +25
18x10 +12, +35
18x12 +0 +20
so thinking ill need 9.5 +25 fronts & 10 +35 rears
this 33 has 9.5+12 all round and looks mint! but no specs on camber ect
Edited by Autumn33
so after working it out on the offset calulator & then getting the trusty ruler out, im thinking i should be able to just get away with the +12's with some more rolling/lipping & stretch
Edited by Autumn33
Not too much to update. Last monday I put a new water pump, idler bearing/new Bolt and tensioner bearing on the old girl along with a new gates timing belt.
Yesterday arvo I made up my rear wing/boot bracing. very light and holds my weight very easily. I have made up a ally plate that fits nice in the passengers side of the boot to mount the surge tank and pumps/pump mounts to so it goes in and out as one piece. will plaster the rising sun over the tank and plate to mtach the engine =)
I'm at a bit of a cross roads with weight atm. I've sorta came a bit of the way and not quite sure where to draw the line. The head unit and 2 door speakers are in question, door intrusion bars along with door glass, might trade it for lexan... I would love to gut the doors and power windows and just have lexan in bare doors but I also want to keep from the B pillars forward in tact. I really want a carbon boot lid and then mount it on pins/latches and do away with the big factory hinges but that will have to wait as the money needs to go on more important stuff ATM
Got a ally rear diffuser/air guide planned for the rear. will get that underway in the next few weeks. more to aid airflow than provide any sort of extra dwonforce as ATM air can get trapped in the rear bar/boot floor area.
cheers
OMG, so much porn in those pics. Heaps jelly of your aero. If I had it though I'd just go backwards over a curb with it :P
Swapping Glass for Lexan I think is time to draw the line, skyline glass isn't that heavy anyway! You're better off spending the $$ on petrol and Tyres :)
its hard Nowelly. I need a new rear screen anyways. And I have spoken to Burgz about getting 2 orders shipped together. should be able to get a rear screen and door screens (and quaters but prob wont use them) in lexan here for 600ish. I was quoted over 300 for an aftermarket rear glass screen.... the door glass is actually kinda heavy. I know the rear isnt.
A nice light motorsport battery is def on the cards later in the year after the important stuff is out of the way.
haha yeah really its not huge coin. not when your already up for a rear screen anyway. its usually about 700 but if we can get two kits at the same time should save a bit on postage, shipping 2 kits compared to one shouldnt make shit all difference so should come in around the 600- maybe 650 tops. I prob wouldnt of bothered if I didnt need any but since I need the rear, kinda a 'may aswell while i'm there' thing lol
looking good Jack
cheers
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
