I don't really want to trade sorry Brian , the only reason im selling is because i honestly have too much sitting around and it's gotten over my head with the workload . Not that there is very much to do to purple , i just need to simplify things a little . If you look in the 4 door section on this site in members rides i just put up a quick list of some of the stuff the car has , id put it here but cbf on my phone . Basically it's a strong 250rwk ish setup
haha nope I like it way to much, after much swapping after getting rid of the sileighty i finally found another car i really like. so its not going anywere till it gets a defect then ill grow some and take it to the track & try to drift :)
little update on it, I had another crack at sanding my cam covers & almost have a mirror finishnow
removed the valley cover & made a bracket for the ignitor
made a cai & pod enclosure
Edited by Autumn33
31 is alive!
Just as well i didn't send the gf off to uni in it tho, i left the afm unplugged and took me a while to figure it out
anyone got a 33 clutch fan that they want to get rid of? i wanna piss this thermo fan off (will swap if you want, has temp controller and relays and stuff but i think the temp controller is dead)
picked up my lexan screens today, arrived along with Burgz's kit.
got it home, have drilled the passenger side screen and fitted the OEM stops, mount studs & roller. great to work with.
rear screen weighs about 4460g
sides screens weigh about 2150g
and rear qtr screens 730 g
OEM side screen weighs about 4700, so less than half the weight. fitment is spot on.
also bought another pair of wheels the same as what i have on the car, but same size and offset as rear.
changed G/box fluid from penrite sin to smurfs blood, leightweight shockproof, instantly silkier.
so ticked a few little things of the todo list. desperate to finish it but the boat ate a big chunk of my funds this month, dammit! not too much further away.
Edited by Mr. Untouchable
got another tire for the 31, watanabe's are back on all round and looks a lot less bogan now (had stockers on the rear)
also found out that they are deffinately welded together :( but still 3 peice
this puts getting the fronts made into rears on the back burner which is sad
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
