picked up my wheels today, just had a chance to test fit them/see how much guard work is needed, but i need to get some longer wheel nuts first.
Here some crappy pics ( the car is still on the jackstands & wheels only sitting on by a nut each )
will post up better pics once its all sorted
post-71390-0-55420300-1341994587_thumb.jpg post-71390-0-99911200-1341994608_thumb.jpg
Edited by Autumn33
Its still on the jackstands at the moment so pics are quite aids, it will be on the ground later today/tonight so i will post up some better pics then.
but because you asked here you go :)
post-71390-0-91050800-1342154290_thumb.jpg post-71390-0-60362600-1342154398_thumb.jpgpost-71390-0-99797900-1342154556_thumb.jpg ( abit dirty they need a good clean/polish)
Edited by Autumn33
Just got it off the jack stands :) Im thinking I will get it out of the garage for some better pics over the weekend.
I have around 100mm clearance at the front bar so its just legal hight wise.
Im thinking of buying some universal bolt on flares rather than going down the GTR or wide body route but ill wait and see.
picture time! (excuse the messy garage ahaha)
post-71390-0-93175700-1342164464_thumb.jpgpost-71390-0-38784800-1342164481_thumb.jpgpost-71390-0-67090000-1342164490_thumb.jpgpost-71390-0-81399900-1342164502_thumb.jpgpost-71390-0-83660100-1342164513_thumb.jpg
it's interesting, I'll wait till I see it in the flesh to pass my final judgement. I reckon it'll have some bozoku style bossness about it, which I don't mind :)
While we're on the topic of wheels I got me some Rays SSR2s 18x9.5 +38, they were gold but after today they're matt black :D
I've got some 245\40\18 Dunlop DZ03G M compunds for them to match the 265\35\18 I've got for the rears :D
What are you doing with your d2r's Pete?
Never really posted any updates in here about our car so thought now might be a good time as there is a fair bit happening. First a bit of background info…
My brother Tom and myself purchased the car, a 1993 R32 GTST, in September 2011 from Victoria, it had an RB25DET which wasn’t engineered so we spent a fair bit of time organising that once we got it back, it was on the road on 11/11/2011 (easy date to remember haha), this is how it looked…
We didn’t really do anything worth mentioning, just tidied a few things up, got some new wheels and went to a few track days at Baskerville.
Then we thought we’d enter the drift practice day in May which didn’t end well with the car being written off, I’m sure most of you have seen pictures/videos and I don’t really want to look at them again so won’t post any of that haha.
Luckily it appears to be only structural damage with only minor damage to engine, surprisingly even front end components such as brakes/hubs were not damaged, the chassis seemed to absorb all the impact.
So we started the search for a shell, nearly bought an S13 which would have been a cool project but ended up getting hold of another R32 in June off DanielH (previously owned by Toffy). Now that we’ve started transferring things across I’m kind of glad we went with another R32 as it makes things soo much easier.
The shell was not quite rolling with no interior but it didn’t matter as we could transfer a lot over from our wreck. During my mid-semester break from Uni we got a bit done…we put in our subframe and front end so it’s now properly rolling (don’t worry everything was checked thoroughly for damage before being bolted up!).
Tom also pulled the RB25 out of the wreck and it has been pulled down to do a few oil control mods (external oil drain, restrictors, baffled sump, oil pump drive collar), head has been decked and replaced valve stem seals, crankshaft seals etc. and the oil pump drive collar is currently getting done. Also discovered big end bearings and clutch are pretty close to needing replacement so figured now is a good opportunity, and rear housing is cracked on turbo (thanks to Tobbie for sorting us out with that and few other bits and pieces).
We’re pretty keen to get it done and get back out on the track again and just enjoy it, I imagine we’ll be taking it pretty easy to start with after all the effort we’re putting in. I guess the good thing about paying someone else to do the work is it doesn’t hurt as much when things go wrong (if money isn’t an issue) but unfortunately that isn’t an option for us haha. I might try and post a few updates as things get done if I have time.
So i got a pair of flares today thanks Damo (DJRIFT) so decided to do a quick mock up
post-71390-0-49570600-1342887865_thumb.jpgpost-71390-0-82309900-1342887885_thumb.jpg ( there not sitting 100% were they need to be i needed stronger tape haha )
They just need a small lip piece cut off then they will fit mint
Edited by Autumn33
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
