so currently my car has a turbo back exhaust and pod filter and boost hits about 11psi and drops to 10, im about to install a jjr return flow intercooler will it make the boost go up again? I know the stock ecu has a shit fit if theres too much boost, should i get a boost t to prevent that from happening? or should it be ok...
A 'boost teee' isn't going to get you less boost.
I don't think you'll see anymore than 1 psi or so increase with a different cooler, if any at all.
Justin.
Edited by XRATED
Ah k yeah I get what you mean, should have thought about that, thanks
Didn't think it would go too crazy, just read things about having too much boost on stock ecu, but I guess it's people turning it up themselves
When you planning on hitting the track Toffy?
honestly im not totally sure mate , i want the car tuned by the end of the month with all the goodies on it i've accumulated , it only needs indicators for the front and a rear ball joint (and wheels, which are on another car) to pass rego which will be done next week , then i can go to town on it :D . hopefully early Feb i want to take it out on a practice day/private track day or whatever you call it to do a little test and tune , then im hoping to make the first drift prac . it could all go to poo if something goes wrong with the car though , but that's my aim :)
When will yours be out and tearing up the track?!
Edited by toffy
I hate setting goals as I always seem to underestimate how much time things will take, but the good news is that everything is starting to go back in the car. I'd like to say it will be track ready by the end of the month but there's a couple of potentially time consuming things that are out of our control, so we'll see what happens :)
installed my return flow fmic wasnt too hard just takes a lot of fiddling around, doesnt help being massively hungover...
pretty happy with it just went for a drive and pretty surprised by the temp diff on either pipe.
next to change my thermostat and coolant then onto powercruise :D
hmmm so i changed my thermostat and bled the system ect ect, then went for a drive and then looked under the bonnet to see that coolant was coming from between the thermostat housing and block, so looks like the gasket sealant i used didnt work/i didnt use enough.
http://www.permatex.com/products/product-categories/gasketing/gasket-sealants/permatex--aviation-form-a-gasket--no--3-sealant-liquid-detail
that is what i used, left it overnight and then filled with coolant.
cause i have to do it again, should i use that stuff again?
i also have this:
http://www.supercheapauto.com.au/online-store/products/Permatex-High-Temp-RTV-Silicone-Gasket-Maker-Red-85G.aspx?pid=114981&menuFrom=51001#Cross
which would be better, i found that the first stuff i used, you couldnt use alot cause it would just drip, sort off cause it was too much like a liquid...
http://www.permatex....t-liquid-detail
i also have this:
http://www.superchea...rom=51001#Cross
rb thermostat gaskets are pretty hard to do with sealant
it took me about 5 goes to do the stagea
the easiest way is to spend $3 on an actual gasket from supercheap
ha ha i was annoyed already at having to do it twice! 5 would make me crack the shits!
but i used the ultra grey and it would perfect.
had no problems at powercruise :D
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
