Spacers on, so much less hover-car-ness
Also some more plasti-dip action (rear gill things)
20130914_170343_RichtoneHDR_zps69731f47.
Also tried my kakimotos on (won't clear brakes without spacers)
Really wish i had a full set :(
(looks high because the suspension hasn't settled, and its pretty high susp too :P)
Have mainly been working on fixing up wiring under the dash, installed gauges, electronic boost controller and removing more sound deadener. Also mounted new wing, and working on front splitter to balance aero :)
kermit3
kermit2
kermit1
Looking good fellas!
I've seen your car out at Shaw(?) a while ago Funz and wondered what was happening with it, good to see you post, you should start a build thread. What's the purpose for the car...sprints, circuit racing?
  • 4 weeks later...
  • 3 weeks later...
Before I call an engineer, can anyone tell me if height adjustable/damper adjustable coilovers can be engineered in Tassie and if so what requirements do they need to meet?
I've looked through the Vehicle Standards Bulletin 14 but this only talks about changing from one suspension design to another (i.e. double wishbone to McPhearson strut), there's no mention of specific requirements that a coilover shock must meet.
Looking at BC BR Type RS which don't have pillowball strut tops or adjustable camber plates.
Hmm that's interesting, I was of the impression you could but wasn't certain which is why I was asking. I'm sure I've seen cars advertised saying they are mod plated for coilovers. It might be best to just speak to an engineer, thanks for the input though, I was hoping someone might have been through the process already who could give me a definite answer
For anyone interested, I spoke to an engineer today who said you can get a mod plate for height adjustable coilovers providing they cannot be adjusted below the minimum ground clearance of 100mm.
And just to cover myself....talk to the engineer you plan to use before purchasing new coilovers ;)
Maybe call the guys at Drummond, proper motorsport shock and spring set and aren't designed to be super low. Mine feel light years ahead of the previous Japanese brand coils that were in the GTR.
J.
  • 2 months later...
so over xmas period i had mandatory leave period so decided to have a proper crack at cleaning up and painting the interior and cage. Managed to find paint in a can that was near spot on to the original interior colour which was good, even a green paint that was so close to my cars colour lol
(remember, I'm not a professional painter, it's not the best job but looks 100x better than it used to, and also.. im lazy)
Also gauge wiring is nearly done, only need to wire up the source wiring to the DIN rail to run everything :)
IMG 4803
IMG 4238
IMG 4236
IMG 4233
IMG 4804
IMG 4839
IMG 4845
IMG 4847
IMG 4883
IMG 4903
IMG 4767
  • 3 weeks later...
  • 3 months later...
Haven't posted on here in a while, I finally got around to fitting my blast pipes sounds mint again although stupidly loud having no cat/mufflers ect, other than that not much else is new.
thinking of selling my gtr wheels if anyone's interested send me a pm with offers/trades
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
    • Sell it and buy a turbo version will make it a lot faster
