What you need a cage for???
Well got my 75K so time to spend some money.
New engine will consist off....
RB25 block, decked and new sleeves put in to accept 93mm pistons. Offset and ground crank, nitrided, blah blah blah, you know the usual.
This should bring the swept volume to 2.9 litters and a 100500 rpm redline.
New sump, and N1 oil pump with modified squirters and return.
Stage 2 pon cams, possible solid lifters not sure. Tomei springs and valves.
800cc injectors, top feed with twin entry custom rail, 3 bosh 040 pumps and surge tank.
I have no idea in regards to engine management, tossing up weather to go Wolf V5 or something similar.
OS Giken clutch twin plate, 2 way lsd, new breaks and suspension, no idea what yet.
Not sure if the set-up will be a big single or 2 smaller huffers. I want response and power.
BUT that is still some 2 years away. At the moment I am acquiring spear engines, to test the crank and new liners, and seeing as I will do all the work myself, should save a fair bit of money.
Keep an eye out.
I want a 100500rpm redline as well :unsure:
looking good stu,
Update for me, Pick up the cage on saturday, hope to install it in the next couple of weeks.
Senssational!
Its gonna be fun next season then, I'll pull to the left to let you through!
Got my front springs (Aurora 7kg 40mm lowered) and rear coilovers (JIC, 6kg) in now. About to change my front tyres for some RE540S I scored from Deane. Cusco cambertops are waiting to go in but I think the spacers they come with require modifying, and my JIC carbon fibre front strut brace is still to arrive.
Fingers crossed I'll have Ben's R34 GT-T intercooler and an SAFC soon.
Have GTS-R wing, new front bar + vents in my study still, bodywork is f#cking expensive!
Really need to get the sills painted white when the other bodywork gets done, the black sills make it look so much higher than it is. Cusco tops will drop the front a little further all going to plan...
Edited by floody
Senssational!
Lol Stu, I'll pull to the left when you lap me!
"thanks for putting me onto the cage"
Edited by woolls
nice ride :)
new front whiteline swaybar went into the R33 last nite....Thanks Damo! and new walbro fuel pump goes in, in a little over a weeks time..........then dyno time MOFO's!
Have to final tune the SM4 and finish setting up the boost controller....it goes like a bat out of hell now! can't wait for the final tune!
Edited by nizmokid
Hey guys,
So anyone seen my old ride kickin around, Someone told me that some young guy bought it. I am allready board of the Evo 9 its just doesnt have as much punch as the old line but the evo kills the skyline in every other aspect by far. So in about a month let the upgrades begin im gonna aim for around 250-270awkw.
Hope it all goes well for you next year Leigh.
Cheers
Alan
Hey guys,
Cheers
Alan
Hey Alan, Hows Qld? and come on, post up a pic of the little beast.
Glad you are happy with the evo, we never seem to be happy with the power :O our cars make. I am looking foward to the tassie series next year, should be good. Got no expectations, just want to get out there, and enjoy the car and have some fun.
cheers
Leigh
Keep an eye out.
Wouldnt 044 pumps be better as the flow more???? I have 2 of these in my 33 and a gtr pump filling the surge tank and they work a treat just a bit noisey. Good luck with the build.
yeah going to look at bennos when he gets back, and the one from eurotech. I will need a running one to test and one to play with, if all goes well, i will sell the kit to stroke and RB25. If i use stock pistons and stroked strock crank i will get just over 2.6 liters.
had a look out our budget, and so far so good. I need my mate to get back from site, he is supervising one of my poject on site, so he can do the crank resizing for me.
Cool, well its a win-win either way i guess if you get either of them!!!
I wouldn't really worry about going any larger with displacment cobber after all it is only a road car that is driven daily :)
Yeah i saw that, but i have some time yet, i need to wait 6 more weeks fo rthe settelment to go through to get the rest of the money. I mean i have it on paper but not in hand. LOL.
hows your rig going?
The 33 is going ok. Took it to bridport yesterday for a blast. Its going really well but i have to get an exhaust for it as its very loud on the highway. It only has the 3inch dump pipes into 4inch collector :).
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
    • If you need to refinance your mortgage and reset the loan terms back to 30 years and cash out on your equity for "investment" purposes *cough* car parts, I can help 😊
