spose ill update lol,
new hks2530 was put in a month or so back same with bosche 040 pump.
have powerfc, injectors and z32 waiting to go in as well as an oil cooler/reloc kit.
new body kit is being worked on and nearly done.
suspension should be here soon..hopefully!
nothing happening to the rx7, but plenty on the mitsubishi side of things... the lancer will soon be ready for new paint.
the skyline goes into the bodyworks for tidy up soon too.
So...
- Now have a TT 5sp Soarer
- Have pulled the turbos off
- Am just about to fit TR43i, stainless manifold, 50mm gate, Walbro pump, FMIC and make custom exhaust and cooler piping
- Just shopping for an adj fuel pressure reg and ecu/piggy back
Also, just picked up our new family bus.
well pick up my car today with the new turbo fitted :) trail fitted the body kit side skirts and rear bar very very average fit :down: will be fitting bonnet tonight, so ill wait and see how good that fits
got the rx7 back with the engine removed! (was going to do it myself but no time at the moment and need to get things cracking if its gonna make the start line next season!)
will now strip the engine of all the crap on it and the gearbox then its off for freshening!
the engine bay is pretty tidy, but will clean it up and repaint.
There will be nothing left if you do that Stu :)
I need a knock sensor to finish my car off :down:
well few pics from todays vist :D
Body kit fitment not to bad side skirts need a fair bit of work but front and rear just a lil trim here and there and will be a perfect fit,
few pics to give you a rough idea of what it will look like when finished :down:
Guess i better do an update on mine, it's sat in a corner of the shed since i picked it up from having the cage done, so this weekend i pulled my finer out and gave the inside a cleandown and started painting it. at this stage it won't be back on the road til jan, but hopefully before christmas. On another note, anyone interested in buying it?
^^^ love the bonnet and a nice choice of kit, 34's can look horribly wrong but that kit makes it look wider and neater.
GT-R made 270kw on 15psi and made 1547.3 n.m of torque.
will wind up the boost (around 22-23psi) next tune to see what i can get out of it.
^^^ love the bonnet and a nice choice of kit, 34's can look horribly wrong but that kit makes it look wider and neater..
thanks mate :thumbsup: well car is now fixed no more break down at 4600RPM coil packs FTL :huh: but all good now :ph34r:
Mines coming back together now. fitted new radiator and put all the loom back and other bits and peices that were removed for the respray. should be on target for a pre christmas finish. anybody got a interior carpet for sale?
    • This is the clearest explanation out of those: Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension. Basically you turn the engine with the tensioner bolt loose, then use the allen key to hold it while you torque it up. And yes after that a good guide is being able to twist it 90o in one of the long free lengths of the belt
    • good choice....I have a set of those and use them all the time including on this job. Plus, no-one wants a damaged nipple
    • Thanks all, went with nismo strengthened belt and all genuine nissan idler and tensioner Question on RB25DET Neo Timing Tensioner: I have a question about the RB25DET Neo timing tensioner. In one of the videos (minute 20 of https://www.youtube.com/watch?v=17y37BB9xnA and minute 27 of https://www.youtube.com/watch?v=Pb99s2E9xUg), the process suggests tightening the tensioner pulley installation bolt to the specified torque initially, and then loosening it slightly to allow the spring to set the correct tension. Is this the correct approach? The R33 workshop manual on page 74 states: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. The way this is written is confusing. Does this mean: Undo the nut, then reduce the tension by turning clockwise? Snug the nut so it stays in position without applying tension to the belt while removing the timing belt? The manual wording makes it sound like the nut will tighten automatically when you turn the tensioner clockwise , which is unclear to me.   Timing Belt Tension Adjustment Process: After loosening the tensioner nut, you turn the engine two full rotations by hand, which should set the correct tension. Once the tension is set, you tighten the bolt to 43 N·m (4.4 kg·m). Before tightening, you need to insert the Allen key into the hexagonal hole to hold the pulley in place while tightening the bolt. In one of the videos, it’s mentioned that you should twist the belt side to side, or turn it slightly to check if the tension is correct. The belt should turn halfway, indicating the right tension. However, I know that twisting or turning the belt is not a good idea. What are your thoughts on this? Finally, how can I ensure the belt isn’t overtightened? I’ve seen many cases where people have overtightened the timing belt.   Manual Excerpts: Page 74: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. Remove the timing belt from each pulley. Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension.
    • Takes a few minutes to malke one. Wood, or steel, or a wrap strap with some strategically placed solids to provide teh drive onto the ribs.
    • I would strongly suggest using the correct tool. They are not expensive and make the job much easier and don't damage the lock ring. Google "fuel tank lock ring removal tool" to see what I'm talking about.
