  • 3 weeks later...
Well my 32 GTR is on the hoist, and about to under go a full overhaul
new motor is built, just a set of CP forged piston's and some Nismo rod's, Tomei sump baffle, Kelford cam's, OS giken cam gear's,
OS giken twin plate clutch and moly flywheel, still need to decide ona fuel rail and injector size
Have removed engine and box, also complete front suspention and x-member, and have stripped to engine bay of everything,
and it's in bare metal ready for a little bit of seam welding here and there, then it's paint time have picked a colour but i not letting
the cat out of the bag on that one....:rolleyes:
here are a few pic's,
post-70098-0-82268400-1299374953_thumb.jpgpost-70098-0-15321200-1299374972_thumb.jpgpost-70098-0-94182900-1299374981_thumb.jpgpost-70098-0-51070500-1299375042_thumb.jpgpost-70098-0-15163300-1299375128_thumb.jpgpost-70098-0-47154900-1299375142_thumb.jpgpost-70098-0-01741000-1299375156_thumb.jpg
Hey zoidbergmerc yeah its a 26 out of a 94 model Vspec1 but it had the longer crank in it and i just got a basic budget reco (as budget as you can anyway) but its basically got Ross forged pistons, nitto rods, ACL bearings, oil restrictors, external oil drain, hi octane sump extension, basic head reco with heavy duty valve springs for poncams later on etc. Really just a full refresh with no heavy machining or over the top parts. I figured if i went all out on it and something went wrong then i would'nt have the money to do it again so i just tried to get away with as much as possible while fixing the factory probs and making it more reliable. I mean nissan knew what they were doing and stock these engines are capable of decent power so with a few new bits it should do what i want for as long as i want well hopefully anyway lol. I would get some pics up but im really struggling to do that ive got them off my iphone and onto picasa3 but i cant seem to get them onto SAU so if anyones got any tips they'd be much appreciated.
Hey mate, where did u get ur engine work done? Wot power r u hoping to make? And wot fuel system r u running?
Hey I pulled the engine out myself but my mate works at Tas Engine Reco in Hobart so they did all the work. I'm putting Garrett -5s on it so I'm hoping for around 340-380kw obviously closer to 380 would be better lol but I guess it all depends on the tuner it should be good for 400 in theory but you know how things vary. As for fuel system I haven't got anything sorted out yet but I have removed all my hicas stuff apart from the hard lines from the front to back and I've heard something about converting them to fuel feed lines cause they're bigger than the factory ones or something like that but I'll work it out. Other than that just a decent intank feeding a surge tank with an external feeding the injectors havent looked at any brands yet. My mate got I think it's siemens injectors in a kit with a rail reg and lines pretty cheap through his work on his 25 and they seem to do the job well. So I'll probably go with those. But really at the moment just a saving game lol. It's true GTR owners are all poor aren't they lol.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
