well im pulling the rear brakes off the 33 tomorrow & giving them a good look over to see if i can get the to work, might need to buy some new lines, will also be pulling apart my power window switches,
dose anyone know were the power window fuses are also?
Just got a call about the sway bars I ordered, would have been here on friday if it weren't for the public holiday, perfect timing for the track day :( Damn you jebus, damn you and your public holidays too
Where'd you order them from?
Bursons Automotive, the rear one had to be made up by whiteline as there was none in stock.
Had a pretty productive day, fitted the front sway bar and pulled off and cleaned all my intercooler piping/intercooler (with the front bar still attached). Ran out of light for the rear sway bar and haven't taken her for a drive yet but hopefully she holds together :)
yeah nice work!
I just tidied up the cable work in my skyline, made it a little nicer.
Waiting for my new gauges and oil cooler to come into stock at SPG then it'll be on!
Hopefully I'll be able to give Funz and Jack a run for their money around basky pirate.gif
How'd you window puzzle go Autumn?
Edited by zoidbergmerc
hey bud sorry i didnt get a chance to bring them back today, there different plugs lol not having much luck but i got some off toffy so ill get it working eventually
no go on brakes tho have no idea whats going on, cleaned my afm & throttle body helped it a fair bit, but you were right after cleaning my afm the a/f ration gauge worked properly & im getting way to much air for the stock afm so time to upgrade to a z32 along with some new silicon joiners for the cooler thumbsup.gif
just the stock ecu but just had a read on here & apparently if i get a safc it will fix my rich& retard problem, anyone have some ideas don't have the coin for a new ecu atm but i need the car so would i be better off going z32 or safc? then when i have the coin going for a nistune or power fc ect
any input welcome
cheers
Edited by Autumn33
yeah will need some kind of new ecu for z32.. not sure of the safc and if it supports it.
powerfc's can be found pretty cheap, RB26 ones can be modded up easy enough for rb25's , like how mine was modded for the rb20
stock afm tend to only struggle when you hit 190kw + from memory.
not sure what im making maybe some one coudl guess lol
mods:
S2 RB25 DET, rb26 crank,forged rods & pistons ACL race bearing and gasket set, metal head gasket.
ported and polished, port matched head
Nismo N1 oil & water pumps.
splitfire coil packs
Turbo smart fuel pressure regulator
Turbo smart bov
Turbo smart boost controller
front facing plenum
3" exhaust
stock rb25 turbo running 10psi & 13psi ( depending on settings )
stock rb25 ecu
just before it jerks around & goes into R&R the a/f ratio goes to 15.1 -15.5 then goes into like error mode & has the hole air side full ( drift defi gauges )
might look into the safc till i can afford the pfc
the apexi SAFC will definatly work with the z32. they give multiple afm options when setting them up.
mods:
Turbo smart bov
front facing plenum
3" exhaust
stock rb25 ecu
nnon of these mods will make the stock afm max out. non of it should affect the reading like it is but in saying that if the fuel pressure has been screwed up that will cause it to run rich with out the apropriate tune. does the red have a gauge on it? its definatly what i would be checking next.
a safc is only a bandaid solution
if you want a cheap option then there is a way of making a z32 ecu run the rb25's and the z32 ecu's can be nisstuned
gt gratage will do nistune install and tune for $1000 but thats for a straight forward install (rb25 neo or s13 etc)
have a look on the nistune site tho, pretty sure it says what you need to do
nistune are underrated and a lot of ppl are pushing decent numbers with them, they also let you keep the stock funtions for things like aircon and cold start and once chipped are as tuneable as most aftermarket ecus
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
