Ah ok then, the fpr has a gauge if that's what you mean I think it sits on 4 -5 psi I don't know about them tho
they shouldnt be tampered with unless you have a wide band oxy sensor ect
But the base fuel pressure should be around 3.5 bar. and rise under load.
if its 4 or 5 bar (big difference) than its probably squirting 10-20% more fuel into the car.
you have 2 options. replace the reg with the stock unit or wind the pressure back. do this at your own risk as you also have the potentual to lean the motor out by doing this as well. if it was my car id have a play with it and see.
Hey autumn I have a safc2 for sale, 250 delivered as new condition with all wiring etc. This will allow you to tune your fuelling and run a z32.
Also if your relying on a drift brand air fuel ratio gauge to tell you what the cars tune is like, your headed in the wrong direction. One of those gauges won't tell you much at all, you need a proper wideband a/f monitor.
I've got some interesting problems with my R33.
Problem #1 When I brake the pedal goes straight to the floor, then upon having a 2nd stab at the brakes it'll be fine, good feel and pulls up fine. Giving the brake a left foot chicken tap before braking doesn't seem to help.
Problem #2 with the brakes, when I'm doing a burn out and having the left foot on the brake the pedal get really hard and pushes my foot off the brake and eventually the brakes stop working and the car will just go forward. (obviously doesn't want to do skids lol)
Problem #3 Steering is really really heavy sometimes, all morning at drift practice it was f**king and the car didn't self steer at all, not when sliding, not when transitioning, not when crusing around the corners in the no drift part of the track, you turn, the wheel will stay at that angle until you change it, and it's so heavy only the hulk can steer it. This problem randomly went away in the afternoon of the drift festival but came back when unloading the car off the trailer. Car is a NA conversion so it doesn't have HICAS.
Suggestions?
I'm thinking the braking problems could be because the NA Brake booster doesn't like being turboed?
probabaly silly question, but have you checked and bled the powersteering fluid?
Checked yes, Bled no, that's this weekends job.
that sounds just like my brake problem.
you can pump them up to hard. Then as soon as you take your foot off its soft as shit.
If I pump mine up it'll stay pumped.
Yours sounds like leaky lines. Had that problem in old Suby wagon.
ive bled them but still no go, did it again yesterday, might look into some braided lines or something :)
Are you doing it right? I remember trying to do it on my old motorbike and constantly f**king it up but not knowing any better.
whats the right way?
i do it like this
pump the pedal till its hard then get who ever to open the caliper nipple then they close the nipple once the pedal has hit the floor
is that the right way lol
Edited by Autumn33
Suggestions?
1# bleed your brakes
2# you need to have a 1 way valve between the booster, and the plenum. You either don't have one, or it's stuffed (pretty commen), one way valve will fix your problems. But remeber, the booster can only hold so much vacume, so depending on the lenth of time your on the brakes, your pedal will get harder.
3# could be your rack, and/or pump.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
