Any reason why your pulling the head off and changing the head gasket??
[/quote
i wanted to make sure it wouldnt let me down replaceing it with a steel one ! :thumbsup:
and i wanted head cleaned up so we get an idea wat condition head and bore is in
Would have been nice to have had the turbo off Twoogle but had so many time wasters with my setup so just going to use it again.
Rob if you dont have this thing at power chews this year im going to kill your babies!!!!!!
id just like to see it run once more. im sure you would like that too.
whos doing the work to your car?
fair enough , for what your plannang with your car imo your wasting $$ is all :) , unless there is a problem with the engine i wouldn't be pulling it apart. just get a compression test done :) and a leakdown test , will give you a fair indication of the engine health
fair enough , for what your plannang with your car imo your wasting $ is all :) , unless there is a problem with the engine i wouldn't be pulling it apart. just get a compression test done :) and a leakdown test , will give you a fair indication of the engine health
I only did so much work to mine straight up because my engine was f**ked when I got it.
Would be nice to have a play at PC but dont want to jinx this engine. lol
Hope to give it a run at the drags with slicks and the big shot of NOS armed as I wont get many runs.
I would be happy to drive the thing as its been off the road for so long. The fastest thing I have driven in years in my 2.6 rodeo work ute. haha
gunna be sweeeeet
Fuel Tek in L'ton
top blokes ! they have worked on all my cars and work mates :thumbsup: :thumbsup: from us
every one has there own opinions of tuners and workshops. if your happy thats all that matters. definatly not the first place i would go but not the last either.
ok its getting the turbo kit installed
head regrind
timeing belt and all others
fuel pump
new fluid all round and a good flush out
new stud kits
new steel head gasket
new intake pipes filter
amd other supporting little things it will need
going to hold off on inject's untill ecu done ,
i was thinking water pump next
would i be worth getting a oil cooler ? or go a new oil pump first ?? :mellow:
just putting it out there ill have a YZF400 4sale soon 2G ,90 model lol need a clutch :)
everyone has questioned why you are changing the head gasket. you can take from this what you like but you are oviously new to skylines.
i personly have never seen an original rb head gasket ever give a problem other than if the car has been overheated and has worped the head. the best way to get a good run out of any skyline is to not toutch the original engine bar providing safety mods. unless you are building race engines, and there is a big difference between race engines and road engines.
take a bit of a look around this site. there is blokes putting out 350-400rwkw on stock un-opened rb25 neo motors. thats in drift cars copping a hiding. one bloke has drifted for well over a year 2 comps a month with 350rwkw on a stock un-opened engine.
you asked about doing the water pump. these are best done while doing the timing belt. im sure your mechanic would advise you of this as the whole front of the engine has to come off to do the water pump so while your in there doing the timing belt may as well do the water pump.
ive also never seen anyone put an oil pump in a rb unless its being rebuilt. the neo rb25 run a bit more refined oil pump than prevous models but the pump isnt usualy an issue unless its on an r32 GTR.
the main point is the money spent stuffing around with the head on and off labour, head gasket, head studs, head grinding would go a long way towards a ECU upgrade.
at a rought guess
head gasket $250
head grind $100?
studs $100?
labour $700?
thats half way to an ecu. or a decent clutch. the ecu will extract good power from the turbo even on the factory injectors. then put injectors in later on. they are one of the easiest parts to change out of all that is listed.
its up to you in the long run mate but theres no need to re-invent the wheel. these engines have been played with time and time again with no dramas with the parts you want to change.
Well I just noticed I hadnt posted the ti up at all.
So far its got s13 bc coilovers
modified knuckles
extra lock spacers
modified radius arms
r32 4 potters
silo lsd
every diff bush is nolithained
lower trailing arms are boxed with 3mm plate
manual conversion
extractors
3 inch intake with pody
18x7 1/2 lensos
at a rought guess
head gasket $250
head grind $100?
studs $100?
labour $700?
I'd definitely listen to damo and everyone else on this.
Replacing parts that arent broken is really a money wasting exercise, unless its a turbo that may fail and blow ur engine.
Removing a head to grind it and replace a stock HG that are capable of 600hp plus is pointless.same for the stock head bolts.
I wouldn't open the engine unless something failed.. by doing it now you will probably pay to do it twice.
Once now, and again for a rebuild if the engine does fail.. wait till it fails, if it fails!
for a plenum, on a stock motor its a waste of money
An ecu should definitely be on the top of peoples modification lists.. e.g. it will make a stock 25 better than one with just a bigger turbo put on..its all about the tune
Edited by jangles
+1 for ECU being #1 mod.
also I got a go pro camera :D
Look how tiny it is when it's not in it's little case!
Tested it out, 720p recording is awesome. It'll do 1080p too but it's not that amazing.
I'll be slapping this on people's cars at the track day so you'll all something to remember the day by.
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
