my remsa pads just arrived from gslrallysport :)
i bought fronts for the stagea (r34 4 pots) and fronts for the corolla (probably overkill really)
keen to see how they are compared to the current pads, just wondering if i should machine the rotors first
QFM pads are best bang for buck pads out bar none. Aus made, and they rock. I run A1RM pads on my car and they are bloody awesome.
and yes, machine away. a fluid flush is always a healthy option too.
these pads sit between the hpx and ar1m aparently, gsl rallysport are phasing out the hpx's apparently because these are supposed to be better for only $10 more ($89/set)
so tempted to put them in tmrw, but i don't want to bed them in twice and it could be a while before i have a spare car again (corolla is up in the air with about half way through a clutch change atm)
little update got my ecu back hello nistune :)
also .. im lookn at getting my frount bar painted and fitted befor i do anything more i F!@#en hate driveing around with it off looks bogan :domokun:
so whats a good place around L'ton to get it painted and fitted @ a good quality for $$$ cheers i looked at micra ?? i just dont know at all pinch.gif
Finally finished spark plugs! Old plugs were gapped to like 1.4mm! Then took it for a Razzle dazzle on some gravel around sandfly. Seems to have a little more poke off the bottom now which is nice. Missing seems to have stopped too :) true test will be tomorrow though
finns body works near the old coats paintens building. they paint all my mates cars and never a complaint.
so nistune arent super fast with there service then?
pic of 34 from back when i was putting it back together :thumbsup:
Looks good Toff...
Sooooo envious- hoist!!! I just spent all afternoon on my back pulling and reinstalling a gearbox in the gts-t. What a pain in the ... well everything!
cheers na nistune where good i wasnt fussed how long it took so i posted it to confidyne and they sent it away with there one i havent been home to check my mail >.<
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
