Camtech 272 duration 9mm lift cams, std rb20det with highflow manifold/turbo/exhaust :)
And Toffy unfortunately it isn't, im not quite there yet with that one, not far off though :thumbsup:
was going to install my safc today but didn't want to risk stuffing it somehow anyone know who can install & tune them? im going to give gt a call monday but wanted to know if there's anyone were else who can do it.
so instead i pulled all my ugly S1 interior out & put in the S1.5/S2 interior i got off petethumbsup.gif
Edited by Autumn33
fianly got a new core for my turbo. rebuilt it and fitted it up. hopefully be the last time i put a turbo on it for a while.
sold off my injectors to make way for some 1000cc jobies.
then to rewire it to tidy up the mess under the dash.
ive almost finished a super light loom for Pete Nunns car. ill be building a similar one for my car. we were able to make it around a third of the original weight. the loom i biult for Bens targa car was about half the original. maybe a bit heavier with the extra bits we needed.
once loom is done ill get a retune then some body work and it will be ready to enjoy.
ah you have to love cars.
.25 of a kg ha ha ha ha ha ha ha ha ah aha ha....
Don't eat dinner the night before... more weight saving! :nyaanyaa:
Ah i get this all the time. this joke is seriously old.
less weight is free power and free brakes. its simple phisics?
how do you think an rb20 powered r32 can lap basky in the times it does? no rb20 r32 has ever done it before? it doesnt have massive hp or belistic brakes?
its not the .25kg from one thing either its .25kg from everywhere.
its not possible to run Nos everywhere Justin. if it was it would probably have it.
sounds good. what kind of weight have you saved with the custom loom?
cheers
the original 32 gtst loom is around 25kg including all the small ecu and control units. bens targa car had to have a fair bit of stuff added over the top of what was stripped out plus it still runs electric windows and mirrors ect.
once you have stripped a car of the easy cheap to remove weights it is hard to find 16odd kg on one area that doesnt cost a bomb so we are pretty pleased with the result.
im yet to do a r33 so im not sure what the starting weight would be.
aparently the r35 has a tun of wiring weight but because of its complexity no one has tampered with it much.
uhhh rightio, good stuff. not something I'm going to worry about unless my wiring ever gives me grief. easy for you i guess as your a auto leccy. I still have a lot of easy crap to kick out so i better attack that first.
Has Brad taken it to any other tracks? or is it fresh and soley setup for symmons atm?
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
