once you paint that it'll look shmick as!
I provide the best in R33 body parts, as you can see in this example, it's come pre-wall tagged and pre-jap stained! If you buy your jeans already f**ked, why not your body kit! LOL!
few quick pics of my datsun with new wing mocked up into position. fixed the few little marks on my drivers side door today and brodie primed it up for me, he also painted his cooler for his GTR.
going to get my beastie painted up and kit back on in the next few weeks. got the oven booked. will get cage in it in a week or two.
getting there, bit by bit
thanks Jay.
scouted the globe for a wing I liked, well to be honest I dont 100% love any wing on a 33. I think the best overall looking wing is the S2 wing. GTR wing is not much chop even on a GTR, S1 is shite, stealth wing is overdone, okay on GTR drag cars. Anyways the point of is it is handling, aero grip. I want to dabble in super sprints and time attack and hill climbs and aero is something I want to play with.
car will be back together soon, will look okay with splitter etc all painted up. will get pics up when I'm done.
the beauty with wings is, they bolt on/off. this is the 4th wing thats been on my car over the last 4 years =)
if I wasnt setting the car up for light motorsports events I'd still have a stealth wing or S2 ;-)
cheers
finally put my new radiator in, fresh green coolant too :)
seems to be working at last but i'm not sure if i should change my thermostat, its a 78.5*c or something on and the stock one was 87 i think (r33'r run an 82)
i was going to put the 33 one back in but i couldn't find it and its not a genuine one (the opening looked smaller between the two)
little update vipec goes in this week also going to piss the cannon off and go twin 3inch stanless insted :D also .. i took my stupid flopping hks digital boost controller out and hooked the std one back up as the vipec uses that cleaned up the engine bay shit loads
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
