Anyone know much about the screamer dump pipes? How well they seal? I've heard they're reallllly leaky
many reports of them not sealing properly, and never sound as good as a true external gate.
also, it really is a pointless modification if only for the sound..
but it is your car so, your choice.
Alottttt of people running screamers and I haven't heard of anyone getting done for anything other than undue noise.. Even my old 25/30 with 4" turbo back with no mufflers just q cannon and screamer I didn't get done :-/
those shithouse dumps are just that, shithouse.
a better way would be to pull the turbo off, tack the internal flap shut and weld a pipe off the exhaust housing, and mount a gate off that, use a V band or 2 or 4 bolt gate no worries. absolute waste of time on a stock turbo but if its purely for sound, much better way to go, there is 1 or 2 decent chinese gates on the market, some of them are shockers.
I'd wait til you get your hands on a better turbo, even a high flow would be okay. then fiting a ex. gate off the exhuast housing wouldn't be quite as much as a waste of time, money and effort.
in other news I've organised a oven for saturday to paint all the bits for my datsun. prepped the front bar last yesterday, just need to prep the front guards and door, and spray them out. will sit the panels back on the car on sunday, except the bar, need to do a bit with motor so wont put the nose back on just yet. just about to go put wheels back on it so i can move the bugger about again.
this fine weather and daylight savings has boosted motivaton lol
What about a low mount with the fitting for a gate there already, and weld the internal gate shut on the stock turbo? Then I can get it high flowed later or go 3082r later. Really I just want the sound at the moment lol I miss gate :(
yeah you can run a ex gate provision off a stock manifold, but welding to cast is a little tricky, but can be done. there are a few places that could do it for you.
other option is to get a old HKS low mount cast manifold with 4 bolt gate provison. rareish, but work okay.
or get a custom manifold built with the gate provision built in. you'd be looking at around $850 min for something decent.
I have a stock manifold here, you could take that and get that modded, I would think you could do the whole thing for 2-300 bux with a cheap gate, just becareful which one you get.
the other end of the scale is to get say Ryan up at ulverstone (capel motorsports) to build you a manifold, he does fantastic work, on par with 6 boost. that will be around 850, then if you buy a genuine gate, say Tial 44 or 46 your going to be up for 1200ish by the time you've done gaskets studs and nuts etc.
I've got a stock manifold too if you want it.
DanialH in the other thread has a high mount external gate manifold for sale http://www.skylinesaustralia.com/forums/topic/374203-fs-brand-new-18x8-and-18x9-wheels-and-hks-2530-turbo/
I got AzCustom to make my high mount manifold and screamer and that was around the $1100 mark, sounds tough as nails though.
I've got a friend that got gate and screamer done on his stock cast manifold, cost like $120 for the guy to do it all, had the gate lying around lol. But was done properly (heating yhe manifold up to the right temp first and cooled down slowly). No eBay monsta high mounts then? :P
hypergear is starting to make his turbo's with dual gates, int and ext
you said you were thinking of a highflow, this will bolt on and use stock dump + have external gate
i had an ebay monsta high mount on my VL, i had to get it redrilled and it leaked like a siz but two gaskets and a whole heap of heatproof silicone and it was fiiiiiiine, well as fine as a bogan spec VL gets.
Who's your friend? i did one like that for someone a few months ago.
Well finally got Jacks parts painted yesterday so he can now get it all back together and hopefully leave me alone for a while lol. Anyway he wanted me to put the pic's up for him.
post-58307-0-53438100-1318125169_thumb.jpg post-58307-0-79724000-1318125238_thumb.jpg post-58307-0-34661800-1318125275_thumb.jpg post-58307-0-73539000-1318125200_thumb.jpg post-58307-0-29643300-1318125142_thumb.jpg post-58307-0-96868900-1318125104_thumb.jpg post-58307-0-31067700-1318125303_thumb.jpg post-58307-0-20663700-1318125338_thumb.jpg post-58307-0-53593800-1318125373_thumb.jpg
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
