Yeah i have a set , the reason i have the gtr rims on the back is because i was trying to fit the 9s' on the front (the fronts are only 8s') . I really want some meister s1s' or something , probably with a black center for something different , i'm a bit over chrome . Those wheels will probably end up on the 32
The ti as it sits now with all thew coilovers, all s13 front suspension, r33 gts t 4 potters, n12 rack ends, s13 tie rods and all nolithain bush it the back
Yes I need to do somthing about the offset on the rear but Might just have to get 35mm bolt ons soon cause moneys to tie up for better offset and width rims
Also got bored and did a garden edging lower lip
Edited by lawler
yeah only reason i went bright is cause the car is black and cant really clash lol... will be getting slammed when i burn these tyres off, then ill get the guards done so i can fit some 245 or something at least under it, 225's dont do it justice from behind haha
how my old girl is sitting at the moment.
Awaiting an oil change, cam covers re installed & a few front bar mods/wiring fixes, should be on the road again by the end of the weekend thumbsup.gif
would you guys advise using bolt on spacers or slip on for 33's?
wanting to pump my wheels out a little before getting some new ones.
Edited by Autumn33
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
