Some Questions About My New Setup
GTR_Junkie
 Share
Guys,
Ive posted before asking if my setup will make 350AWKW, know id like to know the following:
Will the facotry ignition system keep up?
What spark plugs and what gaps?
Will the R33 GTR pump keep up?
What gearbox Oil?
What Front Diff Oil?
What Rear Diff Oil?
To refresh your memmory my setup is
RB26 Head Mildl Ported and Fully Rebuilt
HKS Step 1 272 Cams
HKS Cam Gears
Nismo 600cc Injectors
Apexi Power FC
Nissan Q45 AFM
R33 GTR Fuel Pump
Nismo Adj. Fuel Reg
GCG XTR T60 Turbo
GCG XTR 55mm Wastegate
Custom Manifold (Equal Length)
100mm Thick Cooler
14-Row Oil Cooler
RB30 Bottom End
O-Ringed Block
Head Restrictor Etc
H-Beam Conrods
CP Forged Pistons
ACL Race Series Bearings (Heat Treated Ones)
Straigh Through Exhaust System
Twin Plate Clutch
All this is going into my R32 GTR with a standard R33 GTR box. I dont think ive missed anything let me know if i have
Cheers
Edited by GTR_Junkie
sounds good.
redline oil heavy(red one) in gearbox and diffs.
coils shouldnt be a problem but you may need to gap the plugs down
id use a iq22 denso.(7 range in ngk,0.4mm iridum.)
fuel pump wont cut it.
injectors will be at there max.
youl need a much biger oil cooler
330rwkw 600cc injectors at 90% in my old motor.
oil temp with properly ducted 25row oil cooler still gets up to 115deg from brooklen to berowa. about 5mins flat out.(sock 32gtr)
id run a external 044 with a surge tank etc(unless you always have a 1/4 tank)
if you are going to do it you may as well do it properly.
 Share
