Hey!
I have a coolant leak on the passenger side of the engine.... well thats where the drip is under the car anyway...
Me and a mate originally thought it was that stupid 3inch hose on the drivers side (thats a bitch to get back on too!!) But after starting up...theres still a leak...
Thinking it may be the hose feeding coolant to cool the turbo... (or hoping, coz i don't want it to be the water pump!)
Has anyone else had a similar problem?
Understand its a pretty stupid question, as everyones car is different....but if theres a hose thats prone to go on the RB20DETS it may help me out.... (have only owned car for 3 weeks....its my first turbo too...)
Cheers for ya help!
James
https://www.sau.com.au/forums/topic/91239-r32-gts-t-coolant-leak/
if its time to change timing belt its not a big deal if its water pump.You can presurised water system by testing pump and have a look when engine is not running.I have engine in garage I can have a look what is on passenger side anyway.Give me some idea where is leaking from.
Edited by familka gtr
If its the water pump, wouldn't it be leaking out fast..? Coz its just a drip...
Underneath the car it would be lined up near the turbo area...
Its strange, because i noticed the leak two weeks before it decided to over heat, and it was fine in that two weeks, then all of a sudden it went three quarter hot. When i looked under the car, it was dripping faster.... But now its just back to the minor dripping...
Hopefully that made sense.... :)
Yes they do. I just did a search for "coolant leak" and got this thread, my R33 s2 dropped about a litre of coolant today, and that's just after having the coolant system flushed and replacing the water pump! So it's not the water pump.
I'm buggered where if i know where it's coming from, the farthest i can trace back without starting to pull shit apart is the top of the left engine mount; I noticed a drop of coolant there. Basically what JC said, for all the world it looks like it's coming from the air side turbo / something very close or feeding to it. The other strange thing is it seems to only occur when the engine is cold... However this could be cause it evaporates from the heat before it has a chance to reach the ground/engine mount/whatever.
This just after I think everything is fixed! god dammut. Somebody help us! anyone with their motor pulled half apart around? If not it'll be me tomorrow... I'm meant to be going to the damn Indy and I have a 600k trip to do to get there!
Okay so I just had a quick look on fast... IF it IS coming from the turbo, which i reeeeeeealy hope it isn't, it would probably be leaking from either of the connections circled in red
As I said, I reeeally hope it's not that.. but then, I'm not quite so sure what i'd prefer it to be...If anyone else can shed some light!!!!
Hmmm yeah jezzerr....I was thinking its that too...
But mine happens after it has warmed up....i just started it then and let it idle....after a couple of minutes it started to drip... i had a look underneath, and i can see coolant around behind the water pump, but it drips on the passenger side of the block..not where the pump is...but i guess it could run there....
Could be just a gasket?
How much do you reckon it would cost to get the pump replaced...and the timing belt since you have to take that off...
the guy at import spares reckoned $500!!
I got an aftermarket pump off the shelf! Exactly the same as a VL commy pump - same block. 91 bucks. Going slow it would take one person 4-5 hours to replace. To illustrate, once me and my mate knew what we were doing, it took us an hour and a bit, go to whoa, using all hand tools. It's not really as hard as people make it out to be, you just have to accept that there is no quick way to do it, and it's pretty systematic from there. Just make sure you mark the timing belt location on the cams and the crank, and take good note of the slack in the belt, and remember to only make it as tight when you're putting it back together. Otherwise you have to pull the freaking thing right back apart again!
Timing belts are $140 ish, $60 odd for good coolant, so that's $300 odd in parts, and in all reality it should only take a qualified mechanic with all the right tools 2 hours to do the job, but you can bet your life you wont get the job done for $400 anywhere. add that to the fact that they'll probably find "a worn fanbelt" etc, and you'll be up for $600 at least, vs a day getting to know how your engine works.
Meanwhile, my leak has started up again, I pretty sure it was slow enough that it was just evaporating while the motor was still hot. feeling around as best I could, it doesn't seem to be coming from the turbo... sigh.
it'll run off the lines and not appear to come from the turbo if there is a leak up near the washer..
look, all you have up on the passenger side is either coolant feed or coolant return to the turbo.. so if it is definitely in that area, its definitely the turbo or the lines.
Yeah i got a mate that knows how to replace the pump, so can help me out...
I wanna change the timing belt anyway so thats all good....
Hmm...have to work out my finances by the sounds of it, and i just sold my old car too!! FARK!
Thanks for the help guys.
sounds like your turbo coolant pipes .. they have copper washers as gaskets, replace them
Yeah thats what i thought before... But now i can actually see coolant underneath and behind the water pump area...
  • 6 years later...
having a leaking problem too. only happens sometimes after a long drive. once i stop turn car off it leaks coolant for about 10mins. but no sign of it missing from the container or the radiator :S not sure if its coming from turbo line, when i floor the car past 4k revs makes a funny screaming sound now. no one can seem to help with it.
Edited by AndreW_R32
Jesus 7 year old thread dig up and youve created a new thread.
The screaming sound is probably the studs on your exhaust manifold check all the nuts are up tight I had the two on on number 6 cylinder loose making that noise.
    • Hi everyone, just looking to see what's available in the GTR seat options, testing the waters on what's available. Wanting a driver's seat to replace my old school OG jap race seat, going to re-register the car so need a factory seat. Prices currently seem to go from $300 to $2k for a driver's seat. What's options are there, that's good condition and actually a realistic price? Located Brisbane. Thanks
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
