Walking on thin ice guys , spacers and stud mods are illegal . I wouldn't want to crash it and get caught because you'll wear everything .
That aside the effective wheel offset changes with spacers as does the track . The most common dramas are heavy steering and bump steer . There are wheels out there with the right offset that clear the brakes though 7's are the sensible limit on the front of an R30 . I lucked out and got the right wheels on my DR30 .
disco,surely aftermarket wheel studs are not illeagal???
After fitting some BBS wheels, there wasn't a full nut's worth of thread sticking out on my GTS-X,so had to go to longer units...
I doubt R30's have Australian compliance for them .
I had 10mm spacers on the front of my old R31 when I had S13 offset rims, it it gave me about 8 or 9 turns of the nut, apparantly it's 'safe' with just 6 turns..
surely bolt on spacers are legal?
I will be putting S13 struts in my new 31, and with S13 offset wheels the front will sit perfect, but some nice 25mm rear bolt on spacers would be nice
I paid like $150 for my pair i think from memory Adam...
Disco i don't really have much of a choice atm, im running S13 rims/S13 suspension with R32 calipers at the front and the wheels don't clear the calipers without the spacers :) Im planning on getting some right offset rims in the not to distant future and getting rid of those spacers but for the mean time it'll do
My wheels are the right offset, its just that they were for a Sprinter and they have pissy brakes and unlike the Watanabes and the Enkeis the Longchamps don't have a cutout in the inner side of the spokes to clear decent brakes
Sorry I should have been more specific , need rims with the right offset that clear the calipers . Most late style rims are like this .
RTA hates spacers and long studs because they make the wheel put higher side loads into the ball joints and wheel bearings . This is because the track changes by the total thickness of the spacers and also screws up geometry of in this case zero scrub offset . Bump steer is also not desirable . People have a bad habit of wanting to "fill" the arches and often with over width wrong offset wheels . Also this "dumping the front or nose on the deck" ride height stuffs it all up .
This look the part mostly wont work the part but it does show up the wallys , sorry if this offends but I will never compromise function for looks . The manufacturers are not as silly as many think .
Another thought , those sexy Nissan four piston calipers are not exactly the bees knees - even the R32 GTR ones . For their bulk the pistons are not very big . I have seen VT floating calipers on an R30 that worked very well and it was using 304 x 28 disks with 24 offset 16 x 7's . A very cost effective upgrade for no compromised bling bling ...
Smack me up the back of the head if I'm missing something here...........but I don't understand WTF the RTA would care about longer wheel studs????? They don't change effective track/offset,etc the only difference is there's more stud sticking through the wheel nut (assuming stock style open end nuts)
The only problem I can see with that,is if you have to remove your mags and fit stock steelies....then your 3" studs look like stunt pegs on a pushie :) Ask me how I know
Edited by 0HR-30T
That was all about non std wheel offsets and spacers . Why would you want 3" studs ? Nissan did have an issue with short std studs and alloy wheels but the R31 GTS studs fixes this .
Sorry, you must've missread my post above yours.
"After fitting some BBS wheels, there wasn't a full nut's worth of thread sticking out on my GTS-X,so had to go to longer units..."
IE I needed 3" studs after putting the wheels on as there wasn't enough thread sticking through the new wheels. I'd say my stock HR31 GTS-X studs would be the same length as R31 GTS units,and as I said,they were not long enough. Probably didn't need 3"ones,but meh...
  • 1 month later...
I had to change the rear studs in mine(same as r30)I bought long studs through nice products in sydney(I work at repco)They were too long but the old hacksaw fixed that.
http://www.niceproducts.com.au/
Also found out today that beaurepaires sell the bolt on spacers
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
