i bought a r33 gts-t from the auctions. sounded sweet, drove fine. Got the 100,000 service and mechanic said its fine. then i started noticing shocking fuel consumption!!1 like 290 off the whole tank and alot of black smoke on the muffler. ive driven it for a month and decided to check the oil and its almost all gone :S
does this mean the engine is dead? or something else???
cheers
Edited by mazz
https://www.sau.com.au/forums/topic/91270-new-skyline-from-the-auctions/
yeah like there doesnt seem to be a huge leak of oil any where :S could the mechanic have forgottent o put oil in(doubt it). im not worried about the black smoke cuz i think its petrol not oil but where did the oil go?
the car drives normally, th eoil pressure seems fine and so are the temps? there is no gray/white smoke :S
Edited by mazz
Change the oil again and check it every day to see how much oil it is using.
Black smoke means its running rich - not oily so you may not need to rebuild the engine. It may just need to be looked at by someone who knows what they are doing.
A *little* oil around there is not a big issue, but check the O2 sensor thread. Apparently Nissan recommends changing that sensor every 40,000K's and I doubt your mechanic did that. Then hit up the spark plugs if he didn't change those, if he did, find out what went in there and check that they are the right gap and heat rating.
After all that, reset ECU and let it relearn?
Wat happens is the seal on the turbo goes and it will suk oil through the turbo and out the exhaust
it happened to my TX3T and i needed a total engine rebuild + turbo rebuild and a mates 2.6t sigma engine just rebuilt with no turbo rebuild and his shot oil out of the exhaust
a turbo rebuild solved it
yeah im with R31Nismod heer, if u had low oil ud see the warning lighjt and ur oil pressure would be low :S make sure u check the oil after then engine has been off for a while so it can collect,
cheers
btw if there is no grey/white smoke then ur engine is probably fine, if ur losing oil it might be a gasket somewhere, you should get it checked out either way
Edited by bazz
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
