:( hi all. :D:):)
this ones got me stumped.
i took my car up the old road on friday and now as soon as it heats up the normal woosh noise from the pods changes pitch at about .6bar and over(stock turbos)
its hard to explain its sort of like that to4 bearing type whine but a air noise instaid
sounds like a roofrack wind whistle noise only faster.
you can make it cut in and out by feathering the throttle holding boost at .5-.6bar.
its quite loud. its definatly a air noise,whooshy with a low pitched whistle :huh:
i cheched the front turbo. no shaft play. acualy looks like they have been replaced recently. still has the fluro green paint on one of the blades. :D
havent been able to inspect the rear one yet. due to its flamin mongrely position.
it has no air leaks or exhaust leaks. does not seem to have any performance diferance at all(no extra lag or power diff)
any feedback would be good.
has this happend to anyone after a hard drive?
hopfully il not just add this one to the list of "normal" noises.
Edited by T04GTR
https://www.sau.com.au/forums/topic/91279-r32-gtr-turbo-noise/
ok. ive made some progress.
the noise started about half a day after i fitted a hks front pipe. maybe i had the radio cranked the whole time after i put it on so i didnt notice it.
but i got rid of the noise. by fitting a cat :P
it had one of those pipes on it(i know its ilegal but does good flames)
must of been turbine noise coming through the thin stainless pipe!
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
