hey all, engine of scrutiny is a rb20det swapped into a s14 chassis.
as of late its developed a slight miss at idle and under full boost round 7.6krpm it will cut out for a second and then contiune on.
revlimiter is set at 8.5, but when it hits at 7.6 its pretty rough and doesnt like it much at all......however fuel is not a problem as its about 11.8:1 round there.
ive gapped the plugs down to .6mm now and still no change, perhaps the coils have finaly gone south?
carl
https://www.sau.com.au/forums/topic/91291-odd-revcut/
yah i figured its proly a coil going bad but if thats the case then im just gonna convert to wasted spark.
new coils off ebizzle for 1$usd and some sparkplug leads and some creative wring and all coil woes will be relived forever.
You are dreaming if you think that's the case. Plenty of guys have thought that, most are now back to the original coil on plug set up. The rest sold the car.
A faulty coil/coils do not display all of the symptoms you are describing. Cleaned the injectors lately? Cleaned the AFM lately? Changed the plugs lately? Checked the AAC valve?
:O cheers :)
https://www.sau.com.au/forums/topic/91291-odd-revcut/#findComment-1645514
:( cheers :(
I'm one of them.
I tried running 6 bosch coils and leads after the astounding results of a mate with a CA and then an SR. He could run 1.4 plug gaps and a/f ratios deep into the 10's with no miss (and this was still utilising the stock ignitor).
I could make about 5psi on my rb25 before blowing out the spark if i eased onto the throttle, if i planted the throttle it would just break down and miss instantly. It was wired exactly the same as on my friends SR, i even went and got 2 CA ignitors thinking the internals were bigger as the pins were bigger and ran 3 channels on each, no difference.
Went back to rooted stock coils and it was 200% better, got splitfires and it didn't miss anymore.
https://www.sau.com.au/forums/topic/91291-odd-revcut/#findComment-1647021
hehe, well i was hoping that it would atleast aleviate some problems......
so far in an effort to fix the problem ive removed the maf and given it a good cleaning with contact cleaner (i run blowthru), pulled the plugs out only to find that they are still clean and plenty of life left (gapped down from .8mm to .6mm) and i havent cleaned the injectors as of late........
the aac valve i swapped out a few months ago because i thought the one on my car was faulty, turned out to be an improperly set tps.......
i did clean and lubercate the aac while it was out of the car and it does work fine, idles up when its supposed to.
im gonna guess that i should run some injector cleaner thru my car and see if that helps?
its wholey possible ive gotten some fouled gas as gas shortages (read: gouging) may have caused some stations to put in some dodgy gas in place of premium........
https://www.sau.com.au/forums/topic/91291-odd-revcut/#findComment-1648074
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
