  • Replies 127
ok im in, cruise first sounds better, but we still meeting at the house as will have food and drinks which usually go in the fridge :)
at least if cruise is first we cant get done for drbink drining......
I would prefer the 6th because my car goes into Regency on the 31st of this month. Haha...
Sounds like fun guys, please count me in.
Good luck with the car Busk
Hopefully I won't break anything at AIR the day before otherwise I may need a lift from you mate. <_<
Looks like we have about 15 cars so far.
How does this sound for a timeline?
Meet at my place around 12:00 (drop off any drinks, food and other unwanted weight from the cars)
12:30 departure and cruise and photo shoot (so polish those cars)
2:30 back to my place for a BBQ and drinks
Any suggestions/comments welcome.
(Details such as addresses and cruise routes should be PM'd)
That sounds cool, i wont b able 2 stay 4 the bbq, but im down 4 the cruise. i have 2 get 2 rear tyres by then, incase we run into cops, cos im running on stockies atm. any1 have 2 2nd hand 215/45/17 with a bit of tread lying around?
ok so who lives down south and going to the cruise? ill tag along as i live in sturt. PM me if you are down south and want to cruise there together.
Bloody curbs.......plus towbar and someone wanted to rub against my car with theres! Anyone know where i can get fixed for a reasonable price :P
yo dude im down at woodcroft so ill cruise with you.. B) ill swap you my front bar iff you want.. :lol:
so count me in 4door, ill be wearing my party dress.. :P
Edited by DriftR_33
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
